Introducing the RV6 Precat Deletes/Highflow Precats for the 9th generation Accord V6 3.5L equipped with Earth Dreams engine. We have spent the last 3 months refining this product for perfect fit and function. That means no check engine lights or modifying parts to fit. Everything will bolt on and work on the first try.
Precat deletes aka PCDs and Highflow Precats aka HFPCs replace your highly restrictive original equipment pre-catalytic converters with either a straight pipe or a highflow race catalytic converter.
EGR-B V6 PRECAT DELETES KIT
PCDs
Pros:
Maximum performance gains per dollar
Low cost compared HFPCs
Cons:
May make exhaust too loud for some people.
Stronger exhaust smell
May not pass visual inspection
PCDs Specs:
- 304 Stainless cast stainless flange sections.
- 304 Stainless 2.25” tubing
- TIG welded
- Argon back gassed for pure welds
EGR-B V6 HIGH FLOW PRECATS
HFPCs
Pros:
No exhaust smell
Passes visual inspection
Slight increase in exhaust level
Cons:
More expensive then PCDs
Less power gains compared to PCDs
HFPCs Specs:
- 200 Cell metallic substrate Converters
- TIG welded
Both parts include all necessary hardware for installation. No running around town searching for small parts.
Performance
PCDs and HFPCs have been the proven best "bang for buck" modifications for the J-Series engines 2008. RV6 first introduced a version for the 7th Generation Accord V6 3.0L. Back then people were amazed to see gains well over 15WHP on a 3.0L engine. RV6 has been constantly improving the product ever since.
On our test car we were able to put down some amazing peak numbers using 4th gear which has a 1.024 gear ratio. Since there is no way to hold a gear on the automatic transmission we could not measure the full powerband. We accelerated to 45MPH went WOT and forced the transmission to down shift to 3rd and started capturing data after the transmission up shifted to 4th until before it shifted to 5th.
Test car: 2013 V6 3.5L Accord Touring
Transmission: Automatic
Modifications: None other than RV6 PCDs + HFPCs
Dyno: Mustang MD-AWD-150
Correction Factor: SAE for temperature, barometric pressure and humidity
The results were very impressive. As the exhaust flow freed up the engine actually leaned out and made some impressive power. Once we find a local 6MT we can get a full power band run.
PCDs gains
+37WHP
+23WTQ
HFPCs gains
+26WHP
+23WTQ
Sound Factor
As expected with HFPCs there was no rasp at all and the exhaust note became slightly more aggressive and louder. Unlike the previous Hondas, PCDs did not make the stock 9th gen exhaust raspy. Just louder and very aggressive.
Video: Comparison of stock 2013 Accord precats vs RV6 precats
FAQ
Q: What is a Precat?
A: A precat is a catalytic converter that is bolts directly to the single integrated exhaust port on your engine. The purpose of a precat is clean the emissions produced by your engine.
Q: Why would you want to remove/replace your factory precat?
A: For the automotive enthusiast looking to make more power from a given engine. The best way would be to remove restriction in the induction system and exhaust.
Q: Will the dealer notice this part when I take my car in for service? Will it void my warranty?
A: The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket part. They have to prove that the aftermarket part caused the failure.
Q: Will I get a Check engine light?
A: Generally no if they are installed properly. If you do get a CEL your defouler can be adjusted. We spent a good amount of time tuning our defoulers to run CEL free. If you do get a CEL find out what the code is before calling us.
Q: Can I install PCDs/HFPCs part myself?
A: Of course. Just take your time and do not force anything. Allow plenty of time for installation. We will post a install guide and there are plenty of online resources.
Q: Will my exhaust smell with PCDs?
A: Yes on the outside only. You can not smell the exhaust from inside the car. You only smell it when your windows are down and the wind is blowing the exhaust back at you.
Q: Do I reuse heat shields on PCDs/HFPCs?
A: No, since the PCDs/HFPCs and do no use highly restrictive cores to burn off emissions, they do not get as hot as stock precats.
Q: Will I pass my Emissions test?
A: All RV6 products are intended for Off-Road use only. Technically any modifications related to the engine and lighting are unlawful unless approved by certain government agencies. However these rules are rarely enforced. Most of the performance accessories sold at your local auto parts store are not approved for road use. The states that have emissions testing will usually just plug into your OBDII port and check for codes, which you will pass. Do a little research beforehand.
Q: What does the Ceramic coating do?
A: Ceramic coating is a baked on and cured thermal barrier that keeps the heat inside the exhaust tube and out of your engine bay. This makes for a cooler engine bay and higher exhaust velocities which lead better response.
Q: Can I heat wrap my parts. Will it void the warranty?
A: Wrap all you like. Only cheap stuff breaks when wrapped.
Q: How long is the warranty?
A: 24 Months from sale date. However we take very good care of our customers even outside of warranty.
Q: Can I eliminate X or not use Y part in the installation?
A: The warranty will void if all brackets and mounts are not used. It is not weight reduction it is call being lazy.
PCDs
Pros:
Cons:
PCDs Specs:
- TIG welded
HFPCs
Pros:
No exhaust smell
Cons:
HFPCs Specs:
- TIG welded
Performance
PCDs gains
+37WHP
+23WTQ
HFPCs gains
+26WHP
+23WTQ
Sound Factor
FAQ
