1 - 4 of 4 Posts
Originally, when I bought my 08 EX-L 4cyl auto, I noticed that the rubber molding that goes around the door opening was sagging in the corners. I also noticed it was the case for other 08+ Accords that I was looking at, at the time.
Does anyone else have this problem? Is this easily fixable, or do I need to order new moldings? If there is a TSB, can someone refer me to it? Thanks.
Its known to shrink. I was told that by a body shop guy. Said not much you can do...but pull it all out and press it back in. I used some very thin double stick tape for some of the areas that tend to drape on my 08 sedan.
Hope this helps
You can squeeze the channel back together. If you pull it down a little, you will notice that the channel has wire ribs. You can squeeze them shut and that should do it.
1 - 4 of 4 Posts
