Planning to replace the Serpentine belt as it's original and looks brown and dried out. I also this past winter on sub 30° days, noticed a few times, when the car was cold-started, I heard an almost "electrical" buzz-- like feedback you might get from a radio/amp not properly grounded.. IOW, the pitch of the buzz/whine would increase with RPMs. (The radio was NOT on.) This literally took almost 30 mins of driving to finally disappear each time. (way past the car being warmed up). Obviously I haven't heard this issue since winter time.
As you can see in the pic below, the arrow on the Tensioner is a bit to the right but still in "range" with the short rectangle. (also the pulley condition)
tl;dr: Question is, does that Tensioner pulley need to be changed? It looks discolored/brown also (rusted on the inside track like a rotor?) .. Not sure if it is rust or what. I suppose when I get the belt off I'll see if it spins freely, but not sure about that coloration.
Also, it looks like the Power Steering pump has had some fluid leak out of it a bit. Not sure if it's from an o-ring, or a hose, or if the pump is on it's way out-
(view looking toward back of car)
(view looking toward front of car)
The alternator isn't wet and fluid isn't pouring out, but I suppose it might be slowly seeping out..
--I had a thread this past winter where I was hearing some creaking on turns, but the shop I brought it to couldn't diagnose anything because at the time, I'd noticed my PS fluid was sitting below the low mark, and adding some had (eventually) rectified the issue. I subsequently also had lower ball joints and front&pas motor mounts replaced. I haven't heard the creaking since then.
I'm not keen on replacing the PS Pump rn as a new pump isn't cheap and I've recently put a lot into the car (culminating w a starter, and a 1000 mi drive)
Thoughts?
Thoughts?
