You do realize that using these will require you to remove the rear hubs and replace the stock studs w/ longer ones right?
Are you now on stock wheels? If so, do you plan on keeping them for a while? If so, 20mm or 25mm spacers would probably look better, and they use the stock studs, so no removing the hubs. Just a thought.
