1 - 7 of 7 Posts
‘20 Accord Sport 2.0 6MT
Coming from a ‘20 Si coupe, mid-July had a lady use my car as a brake/wall and crushed me hard, zero brakes applied on her part.
Anyways, I knew the car was going to be totaled, so began a search for a replacement. Was going to grab a new RDX A-Spec or TLX A-Spec, but honestly still MUCH prefer a manual versus an autotragic (just not as engaging or fun to drive). Timing was just right and found a ‘20 Accord Sport in white (prefer my Honda to be white) in my area through a private seller. It was fully stock, except for replacement LED high beams and I guess the rear lower valance is done in black. Picked it up August 18th and immediately began to transform it to my vehicle.
Wheel Tire Car Sky Cloud
Car Speedometer Vehicle Gear shift Automotive lighting
Momo 280mm wheel, controls rewired, tucked for now till I figure out how I will mount them. Hybrid-Racing Titanium shift knob and boot collar. Zoom Engineering carbon Penta rear view mirror
Fluid Material property Auto part Gas Rectangle
HASport 88A durometer mounts
Wheel Tire Car Vehicle Automotive tire
Land vehicle Car Vehicle Motor vehicle Automotive lighting
Bride Carbon Aramid ZetaIII on Bride non-sliding FX rails, Cusco chassis braces
Automotive tire Vehicle Hood Purple Motor vehicle
Full Acuity shifter upgrades, do wish Hybrid-Racing and/or Acuity made a full replacement setup
Car Motor vehicle Automotive battery Hood Vehicle
AnitGravity battery held in place with ChasingJs Titanium stay (31lbs lost)
Bicycle accessory Bicycle part Rim Automotive tire Bicycle drivetrain part
RV6P rear stabilizer and end-links
Bicycle part Bicycle drivetrain part Auto part Metal Rim
RV6P rear toe arms
Wheel Tire Automotive tire Locking hubs Tread
ARP extended studs (only in the rear for now).
Some more done to it.
Wood Handwriting Rectangle Wood stain Font
SWIFT springs
Bicycle part Wood Font Machine Hardwood
RV6P front compliance mounts
Tire Wheel Locking hubs Vehicle brake Automotive tire
Two Seven One BBK outfitted with ProjectMu HC+ pads (also have PMu HC+ pads in the rear with some slotted R1Concepts CarbonGeomet rotors)
Automotive fuel system Automotive tire Motor vehicle Vehicle brake Suspension
ProjectMu full stainless lines front/rear
Motor vehicle Bumper Automotive exterior Font Wood
Hondata FlashPro
Gadget Bumper Automotive exterior Grey Hood
Mugen pedal covers (sticky icky)
Have lots of PRL stuff on order, but as is typical these days everything is on back order. Not a fan of any of the exhausts made for this chassis, so eventually will have a custom 80mm Titanium made and most likely unseen feeding into the stock feux outlets within the bumper.
Have a FK8 flywheel and clutch on order to replace the ridiculous dual mass flywheel. To shed a nice bit of weight from the drive train. Speaking of weight, have already shed 170lbs with what I have done so far.
V4 Watch
Something to keep in mind when you remove airbags, unless you are running a HANS, which i suspect you are not in a street car.
I think you have lost your mind doing all those mods. Just kidding good job. Those mounts look nice now if someone would make some for the 9g Accords.
Reactions: cg555sd
Well been driving for over 30 years, most of those years without an airbag, in fact pretty much never an airbag and I’m still around driving, but thank you for your concern. If it is your time it is your time.
What's your opinion on the 27Won kit.
It’s decent and even better when I changed the pads to ProjectMu HC+ compound (0~800° C temp range).
2019 Platinum Pearl White 2.0 Sport 6MT
Wow, you really went all out. How do you like those seats? How much did they run (with install), if you don't mind my asking?
Discussion Starter · #7 ·
Install was free as I do most things myself. 😉 Way more comfortable compared to the stock seats and I’ve been using a set of ZetaIIIs going way back to 2005 and my DC5R back in Japan, followed by an AP2, GE8, FC3 and now CV2. Once in them, nothing else as comfortable for myself. May eventually spring for the newer ZetaIV, but would need to be all black as I dislike the look of the red model.
1 - 7 of 7 Posts
