I installed the FOURTH passenger door lock actuator on the '03. Yes, the previous two were cheapies. This one is from Autozone, and has a lifetime guarantee.
I went with the stock tire size for the TL, 235/45 R17. In hindsight, sticking with narrower tires would probably be better for my fuel economy, but so far I haven't noticed much of a decrease.@capkirk123 those are actually 07-08 wheels. The TL was refreshed for 07-08 and had those wheels, 04-06 had a different set.
But you're not kidding that they're wider.
Your stock 7.5 Gen V6 wheels: 17x6.5 +55 215/50R17
07-08 Acura TL (Base & Type S) wheels: 17x8 +45 235/45R17
So the TL wheels sit 30mm more outboard, and 10mm more inboard than your stock wheels.
What tire size did you go with on the TL wheels? They look pretty wide.
Low end torque mainly. Definitely a big difference on the lower gears.So what makes it better?
I wouldn't say more power, just better throttle response on the lower gears. Haven't really dyno'd the setup but maybe a couple of HP. Who knows🤷♂️supposedly it makes more power
Checking vehicle tire sizes at Tire Rack, yeah the 17" wheels on the TL are wider than stock Accord, and quite a bit more expensive per tire, if that matters. It would be interesting to see how the handling feels.Got brand new tires mounted and balanced on some 06' TL alloys. They were a heck of a steal, $25 each off a junkyard car. They're about an inch wider than the factory alloys, slightly lighter(?), and I think they look better (they certainly looked better than my flaking and corroded alloys).
They ended up being a bit wider than I expected, but I kinda dig the look. Unfortunately, they did not get rid of the vibrations above 55 (in fact, they feel a bit worse), so it looks like I need new CV axles soon. Still, 200k miles is pretty good for the factory ones.
The handling feels pretty similar, and steering isn't any heavier. However, it does have a lot more grip on dry pavement. I can barely spin the wheels anymore, and it turns much better.Checking vehicle tire sizes at Tire Rack, yeah the 17" wheels on the TL are wider than stock Accord, and quite a bit more expensive per tire, if that matters. It would be interesting to see how the handling feels.
I put 17x 7.5 wheels on mine and they work with the same tire size. The General Altimax RT43s I have work for up to 7.5 inch wide wheelsThe handling feels pretty similar, and steering isn't any heavier. However, it does have a lot more grip on dry pavement. I can barely spin the wheels anymore, and it turns much better.
