Installed refurbished steering wheel and new hood insulation.
Wished my car had an engine in it.
Screw the engine, put an electric motor in it. 🤣 😂Installed refurbished steering wheel and new hood insulation.
I needed a helper, but installing the spring on the hose, then installing the hose on the airbox, seemed to work the best. The hose is flexible, but if it's already attached to the airbox there's just not enough space to work.Any tips on installing spring around the corrugated rubber hose towards the airbox, item 7 ? Air Cleaner (V6) for 2006 Honda Accord | Conicelli Honda Parts
Install the spring first, before slipping onto the air box. use needle nose pliers to hold one side, then another pliers (or hook) to pull the other end to hook up.Any tips on installing spring around the corrugated rubber hose towards the airbox, item 7 ? Air Cleaner (V6) for 2006 Honda Accord | Conicelli Honda Parts
@StimulusAccord
Please check out this post from my window switch experience. It may help you.
One owner '03 Honda Accord EX V-6 6-spd trying for...
I'm starting a thread to document the push to get our Accord to one million miles and beyond. My wife bought our Accord at Pensacola Honda in 2003. It was her primary car for several years and now it is my daily driver. It has been a phenomenally reliable car and is still in great shape...www.driveaccord.net
Hey, I did that with my diesel buddiesA bunch of old timers were congregating yesterday on parking lot of local O'Reilly's auto with their mustangs, I thought about pulling into the lot and flex with my 7th gen to add some color to that boring party. 🤣 😂 🤣
I've seen somewhere that you need to get the driver main/master window switch correct to your trim as it was different for lower trims.I checked .. I think the switch I have is a bad one. Since I do not have a rush then I will wait to get another master window switch from the salvage yard, assuming it does not get pulled on day 1.
I also started reading through the whole thread. Really interesting! Next time I need to get myself a car from the south without the rust.
Nice, my two cars next please 🥺Washed off the pollen.
