It's fair in the sense that you could go to any Honda dealership and they would charge you the same 0.8 hours for labor.I was charged 0.8 hours for the spark plug install on my 2007 Accord 4 cylinder.
Does that seem fair to you guys?
Learn to do your own maintenance and save a lot of money. I just got an Accord with 80k, bought the NGKs and a $40 torque wrench so that I could torque them correctly, and I still paid less than if I had someone else do them, and now I have a torque wrench for the future.Oh heck - well, this was an independent mechanic. I was hoping they'd charge less for labor than a dealership, but apparently not.
That's disconcerting.
Ditto X 10!NGK all day long.
I'd suggest doing them yourself. I am not a mechanic by any means, and I did mine in 45min with the help of a friend.Oh heck - well, this was an independent mechanic. I was hoping they'd charge less for labor than a dealership, but apparently not.
Which is 0.75 of an hour.I'd suggest doing them yourself. I am not a mechanic by any means, and I did mine in 45min with the help of a friend.
Which is not far off from the OP's quoted time. Not bad for someone inexperienced like me :grinWhich is 0.75 of an hour.
You're right, I should learn to do it myself. Be a good learning experience.I'd suggest doing them yourself. I am not a mechanic by any means, and I did mine in 45min with the help of a friend.
I've never used a torque wrench for plugs. Probably never will. The antiseize that I add to the thread would throw off the torque anyway. Just past snug is all you need. You have an i4, the plug won't back itself out like the V6 #5 plugs do.You're right, I should learn to do it myself. Be a good learning experience.
Maybe it's the torque wrench - thought of over/under tightening that scares me away from it.
This made me laughgreyhonda said:Which is 0.75 of an hour.
It's good that you got them replaced either way. I'm not good at doing my own maintenance as wellYou're right, I should learn to do it myself. Be a good learning experience.
Maybe it's the torque wrench - thought of over/under tightening that scares me away from it. I'm by no stretch of the imagination a mechanic. Like the fella above you mentioned - youtube video will come in handy.
At least I don't have to worry about it for another 100k miles.
How much do you pay for an oil change?I do small things by myself, like changing the air filters, and spark plugs. I know some will not understand this here, but I don't do oil changes myself, I find I don't save that much money and time compared to just taking it to the mechanic, but that's just my opinion.
