1 - 10 of 10 Posts
This is another upgrade than I've done on previous vehicles, usually with results that justified the investment. However, the present condition of my stock braking system @ 119k miles is actually pretty good. It was obvious that the p/o had recently installed new brake pads, my original hoses are still in decent shape, and I'm not dissatisfied with the amount of pedal pressure that I already have. So, before I sink $100+ for a set of StopTech lines & brake fluid....do high quality SS braided brake hoses make a substantial difference on a 7th Gen.?
Any guidance from those 'in the know' is greatly appreciated. :thmsup:
Carpe Diem
My answer would be no, it is not worth it. I installed SS lines in the front when I originally installed my Wilwood BBK. 5-6 years later I had one line fail on me while driving to work and lost all my brake fluid and in turn lost most of my braking power. Very scary. I went and bought two OEM rubber brake lines and removed the SS lines for good. I noticed almost no difference in braking power between the rubber and SS lines.
Did you make any modifications to the brake system that increased the brake fluid pressure? No. Do you tokyo drifto on your hydraulic hand brake a lot? No. Then you don't need anything other than factory spec lines.
Not really, unless you race your car.
And even then, I did this mod in 2007 on my 05, and last year I had to replace the lines as they rotted inside the banjo fitting...
Reactions: CarDaddy
SS brake lines do nothing to improve braking power, they just change the brake pedal feel a little bit. Put your money into better pads and high carbon or cryo treated rotors instead.
I second the "better pads & rotors" argument, but I don't think you need anything extreme for a good improvement in stopping distance and pedal feel. I got the "quality" version Raybestos pads and rotors and was immediately impressed with the changes. I LOVE the feel and performance, my only concern is that it seems I could stop much faster than most people behind me in an emergency situation (idiots of Maryland have no sense of "safe following distance").
Discussion Starter #7
:thmsup: Thanks folks, I really appreciate the strait-forward answers. Looks like I'm just going to do a complete brake flush w/DOT4 and call it a day.
I did a brake job on my v6 6speed, replaced rotors, calipers, pads, and ss brake lines and found the pedal feel much improved. I admit it is more noticeable during a hard stop. I have some Eibach springs, and Tokiko shocks set to their firmest settings. I travel a lot on secondary roads, admittedly at higher speeds, so good brakes are important. If you will never need to stop hard from a hundred or so then OEM is just fine. But, if you have ever done a hard high speed stop with the standard OEM system, you can be out of braking power after one hard stop. There were times I would have the pedal clear on the floor and smoke in the wheel well. The SS lines do a much better job of engaging each caliper equally.
Discussion Starter #9
Sorry to wake this one up, but I did eventually opt for a complete set of StopTech performance brake lines. Braking feel is greatly improved, even with the stock brake set-up. Not only is the brake pedal firmer, but whole braking system now has a much more balanced feel. The front end no longer seems inclined to dive under moderate braking which has changed how I use the brakes while cornering. Poor investment?.....not 4 me .
1 - 10 of 10 Posts
