So I've ordered the following housings form Amazon along with some Mini H1 6.0 projectors with mini graphite shrouds and xBaLED 80 mm White rings to put inside the shrouds
Depo 317-1131P-US2 Honda Accord Headlight Unit with Black Bezel
Here is the initial wiring diagram for anyone interested. But basically the harness I made provides the following:
- Combines the Accessory and Parking Light signals in to one PK/ACC signal
- The PK/ACC signal powers the LED fog lights and the LED angel eyes so that they come on with the car in RUN/START or when I lock/unlock the car
- Maintains DRL operation of the 9005 bulbs as long as I don't remove the fuse under the dash, I also have a separate switch do do this
- Seperates the DRL signal from the solenoid so it doesn't wear out the solenoid
- Allows the stock high beam to trigger the solenoid only when the low beam is engaged, this allow for quad high-beam
- Uses a low beam signal to trigger a relay harness providing full voltage to the HID's direct from the battery which also has a new second direct fused line from the alternator
Here's the small PDF download and the large PNG to follow it. I'll take picture of the harness tonight before I fit it in the car and trim it down to only the size it needs.
http://store.axihub.ca/images/extra/Stella_Schem_S1-Model.pdf
