1 - 3 of 3 Posts
Please check the groan this steering makes.
Also check the rattling noise engine makes in Drive mode.
I also get vibrating noise from engine at low rpm
Check your power steering fluid. If the fluid is low, it will cause a weird noise and/or be a stiff.
For the rpm, get your catalytic convertor and solenoids checked.
That should do it! :)
You might need to change the o-ring of the power steering pump. Easy fix. I also have a rattle on D and stopped which comes from the cover of the catalytic converter under the car. I will take care of it after the winter - if the cover is still there. You haven't told us your car's info though.
1 - 3 of 3 Posts
