Hi,
I'm new to this forum and i'm trying to help a neighbor fix there leaky powersteering hose thats been leaking for well over a year.
I tried tracing back the hoses, and it lead to one of the two hoses right under the exhaust manifold. I dont believe it is the high pressure hose because I pulled off the heatshield, and I couldnt see a leak from the fitting area under the rack. The other hose right beside it, was drenched had a leak, and believe it had spread to the other. The problem is that its in a real tight location, right under the rack and a frame member? Any thoughts?
Thank you
Thank you
