1 - 11 of 11 Posts
07 V6 EX-L
I was able to cut the bolt and any recommendations to get the half bolt loose? I guess i accidentally spilled some water in the trunk and totally forgot about it later on.
Can I thread two nuts on it and wrench it out? What size of the thread?
Pilot without a plane
Oh that looks familiar. I had water seeping in my trunk and didn't know it. My bolt seized and then broke off when I tried to unscrew it. You may be able to spray some PB Blaster on it and work it out, but I doubt it.
I fixed my trunk flooding problem and just put in a full size spare. It just lays there not bolted down, but it doesn't mind. My trunk carpet sticks up a couple inches now, but it's worth it to me to be back up to highway speed if I get a flat.
Check your trunk after car washes and rain to see if it's still getting wet. Took me awhile to find my problem. Water came in by my left taillight.
2019 2.0 EXL
Maybe soak with some penetrating oil over a night or two, vice grips, maybe carefully apply some heat? Possibly weld a nut onto the bolt and then use that to turn it/break it free?
Maybe just put threads on what you have left over and find another way to secure the spare (e.g. like a washer and wing nut type of design)
You'll have to soak it in penetrating oil overnight and vice grips may still slip while trying to remove it. Best way would be to get a stud remover similar to the picture which bites harder as you try to turn the stud.
Sent from my SM-N975U1 using Tapatalk
07 V6 EX-L
Discussion Starter #5
Thanks. I will try it over the weekend. I also had a stripped bolt on the engine air filter.
Do you have a picture? That will probably be most easily resolved by getting the part from a junkyard
If you find that thing is in there good, or just decide to leave it alone: Drill and tap a hole in it, use a smaller diameter bolt to hold down the spare.
07 V6 EX-L
Discussion Starter #10
Some updates after only two minutes try. I was using a vise grip and turn it back and forth. All the sudden I felt it was loose. And it turned out that the nut welded to the base was rusted so bad and became detached. Well, I am gonna leave it as is, and use a long zip tie to secure the tire. Saved at least $30 to buy additional tools and parts
Zip-tie to the rescue. I had a $600 car that was held together by zip-ties, bailing wire, and duct tape. Just keep an old pair of wire cutters back there so you can cut the zip-tie when you need to change a flat tire. Not that you would have been able to before that either.
1 - 11 of 11 Posts
