around 800.. i was looking at blackworks, megans, or D2.tein ss-p. How much money do you have to play with?
going 2-2.25 inchesTeins good, BC, Megan Racing, etc.
What is your budget and what are your goals? Teins can sometimes be restrictive of going low.
you do know that the GC that fit on stock shock will not fit on koni yellow right? The koni are fatter and the gc can't slide in unless you get new holders.Well if you're on a budget. Get some Ground Controls, you can also customize spring rates. They're compatible with OEM shocks, but eventually you'll have to change them. And when you do, go with Koni Yellows :banana:
+1 thank you!!Suspension.
Whoops! That was on me, my bad OP don't listen to me haha.you do know that the GC that fit on stock shock will not fit on koni yellow right? The koni are fatter and the gc can't slide in unless you get new holders.
also blackworks & or D2 ebay brand right?
megans okay
