1 - 20 of 1706 Posts
· ↑ ↑ ↓ ↓ ← → ← → B A
Available Now:
Honda Kit
Honda HFP Sport suspension - springs and struts (installation instructions: mirror 1; mirror 2, mirror 3)
Part #: 08W60-T3M-100
Drop: 15mm front , 15mm rear
Warranty: 3-year/36,000-mile when installed at the time of new vehicle purchase
Lowering Springs
D2 Racing
Part #: D-SP-HN-09-1
Drop: 2.0" front , 2.1" rear
Spring Rate: progressive
Warranty: lifetime
Eibach
Model: Pro Kit
Part #: 4089.140 (V6)
Drop: 1.3" front , 1.3" rear
Spring Rate: progressive rate of 3.37-5.42 kg/mm (188-303 lbs/inch) front , 1.54-4.19 kg/mm (86-234 lbs/inch) rear
Warranty: 1 million miles
Part #: 4090.140 (I-4)
Drop: 1.0" front , 0.7" rear
H&R
Model: OE Sport Spring
Part #: 51846-55 (V6)
Drop: 1.0" front , 0.2" rear
Spring Rate: ?
Warranty: lifetime
H&R
Model: Sport Spring
Part #: 51846 (V6)
Drop: 1.3" front , 1.2" rear
Spring Rate: ?
Warranty: lifetime
H&R
Model: Sport Spring
Part #: 51845 (I-4)
Drop: 1.2" front , 1.2" rear
Spring Rate: ?
Warranty: lifetime
Megan Racing
Model:
Part #: MR-LS-HA13L4 (4 Cylinder)
Drop: 1.0" front , 1.2" rear
Spring Rate: 189 lbs/inch (3.39 kg) front, 214 lbs/inch (3.83 kg) rear
Warranty: 1 year
Megan Racing
Model:
Part #: MR-LS-HA13V6 (V6)
Drop: 1.1" (28mm) front , 0.7" (18mm) rear
Spring Rate:
Warranty: 1 year
RS-R
Model:
Part #: H137D
Drop: 20mm to 25mm (0.8" to 1.0") front, 10mm to 15mm (0.4" to 0.6") rear
Spring Rate: 3.67kg/mm front, 4.59kg/mm rear
Warranty: ?
Tein
Model: S. Tech
Part #: SKHD6-AUB00 (4 door)
Part #: SKHF8-AUB00 (2 door)
Drop: 1.3" front , 0.4" rear
Spring Rate: 3.81 kg/mm (213 lbs/inch) front , 3.92 kg/mm (219 lbs/inch) rear
Warranty: 1-year defect and sag (Covers over 5mm sag, breakage, deformity, and noise. Does not cover powder coat finish and rusting)
TruHart
Model:
Part #: TH-H410
Drop: 2.0" front , 2.0" rear
Spring Rate: ?
Warranty: lifetime
Struts/Shocks
KYB
Model: Excel-G (OEM Replacement)
Part #: 3340123, 3340124, 340031, 340049
Warranty: Lifetime
Monroe
Model: OESpectrum Strut
Part #: 72971 (front left), 72970 (front right), 72984 (rear)
Warranty: Limited Lifetime Warranty
Monroe
Model: Quick-Strut Complete Strut Assembly
Part #: 172971 (front left), 172970 (front right), 172984 (rear)
TruHart
Model:
Part #: TH-H510
Warranty: ?
Coilovers
AMR Engineering
Model:
Part #: link
Damping:
Spring Rate: custom
Warranty: Lifetime
MSRP: $1,595
BC Racing
Model: BR series
Part #: A-103E-BR
Damping: 30 levels
Spring Rate: 7 kg/mm (392 lbs/inch) front , 6 kg/mm (336 lbs/inch) rear
Mono tube
Warranty: 1 year
MSRP: $1,050
BC Racing
Model: DS series
Part #: A-78-DS
Damping: 30 levels
Spring Rate:
Mono tube
Warranty: 1 year
MSRP: $1,300
* custom spring rates and Swift spring upgrade also available
D2 Racing
Model: Racing Street (RS)
Part #: D-HN-09-1
Damping: 36 levels
Spring Rate: ? / ?
Warranty: 1 year
MSRP: ?
Fortune Auto
Model: 500 series
Part #: FA500-UA8K13
Damping: 24 levels (rebound)
Spring Rate: 10kg/mm front , 6kg/mm rear
Warranty: 5 years
MSRP: $1325
* RDC (Remote Damper Controller) available:
MSRP: $699
Function Form
Model: Type I
Part #: F2-CTCRT1
Damping: none (pre-tuned from the factory)
Spring Rate: 12kg/mm (672 lbs/inch) front , 8kg/mm (448 lbs/inch) rear
Warranty: 1 year
MSRP: $860.00
Function Form
Model: Type II
Part #: F2-CTCRT2
Damping: 32 levels
Spring Rate: ? front , ? rear
Warranty: 1 year
MSRP: $1,225.00
Godspeed (GSP)
Model: MonoMax
Part #: MSS0440
Damping: 16 levels
Spring Rate: 8 kg/mm front , 6 kg/mm rear
Mono tube
Warranty: 1 year
MSRP: $700.00
Godspeed (GSP)
Model: MonoMax
Part #: MMX2540
Damping: 40 levels
Spring Rate: 14 kg/mm front, 10 kg/mm rear
Mono tube
Warranty: 1 Year Warranty from Date of Purchase
MSRP: $900.00
Ground Control
Part #: 4518.01
Drop: 0" to 2"
Damping: 0 (uses stock shocks)
Spring Rate: ? / ?
Warranty: lifetime
MSRP:
JDM Sport
Model: DL series
Part #: 131-1048
Damping: 32 way
Spring Rate: 8 kg/mm (448 lbs/inch) front , 6 kg/mm (336 lbs/inch) rear
Mono tube
Warranty: 1 year
MSRP: $899.99
KSport
Model: Kontrol Pro
Part #: CHD400-KP
Damping: 36 levels
Spring Rate: 9 kg/mm (504 lbs/inch) front , 7.2 kg/mm (402 lbs/inch) rear
Warranty: 1.5 years
MSRP: $1,000.00
Largus
Model: Spec S
Part #: 01011203047
Damping: 32 levels
Warranty:
MSRP:
Motion Control Suspension (MCS)
Model: multiple custom-built options available -- 1WNR; 2WNR; 2WR; 3WR
Part #: n/a
Damping: 18
Spring Rate: custom
Warranty:
MSRP: Varies. Depends on model. ~$2,800 and up
Megan
Model: EZ Street
Part #: MR-CDK-HA13-EZ
Damping: 15 levels
Warranty: 1 year
MSRP: $799.00
Megan
Model: Street
Part #: MR-CDK-HA13
Damping: 32 levels
Warranty: 1 year
MSRP: $999.00
Riaction (Five8 Industries)
Model:
Part #: RIA-CTCRSS-2
Damping: 32 levels
Spring Rate: ?
Warranty: 2 year “manufacture defect” warranty
MSRP: $1,092.00
Standard (STD) Suspension / Scale Suspension
Model: Innovative Series
Part #: HD05-IS
Damping: 12 levels
Spring Rate: 8 kgf/mm front , 6 kgf/mm rear ; custom spring rates available
Warranty: 2 years
MSRP: $1,245.00
Silvers
Model: NEOMAX
Part #: SILVER-NH135
Damping: 24 levels
Spring Rate: 10 kgf/mm front , 6 kgf/mm rear
Monotube
Warranty: 18 month limited
MSRP: $1,149
* Custom spring rates and Swift Spring upgrade available
Tein
Model: Street Basis
Part #: GSHD6-1USS2
Damping: none
Warranty: 1 year
MSRP: $650.00
Tein
Model: Street Advance
Part #: GSHD6-2USS2
Damping: 16 way
Warranty: 1 year
MSRP: $760.00
Tein
Model: Flex Z
Part # : VSHD6-CUSS4
Damping: 16-level Linear
Spring Rate: 8 kg/mm (448 lbs/inch) front , 5 kg/mm (280 lbs/inch) rear
Warranty: 1 year
MSRP: $1,010.00
* EDFC available: part # EDK05-10120
Truhart
Model: StreetPlus
Part #: TH-H810
Damping: ?
Spring Rate: ?
Warranty: 2 years
MSRP: $595.00
Yellow Speed
Model: Dynamic Pro Sport
Part #: YS01-HD-DPS062
Damping: 33 way adjustable
Spring Rate: 8 kg/mm (448 lbs/inch) front / 7 kg/mm (400 lbs/inch) rear
Warranty: 24 month limited
MSRP: $1,420.00
OE Alignment Specs:
Front:
OE Camber = -0.3 deg (+/-0.5 deg)
OE Caster = 3.9 deg (+/-0.5 deg)
OE Toe = 0.0 deg (+/-0.3 deg)
Rear:
OE Camber = -1.3 deg (+/-0.5 deg)
OE Toe = 0.3 deg. (+/-0.3 deg)
Looks like it's a good time to put some money aside for all the additional toys to be put on our rides when they are available next year! :thmsup:
· 2013 Sedan Sport
the rear naturally sits higher from the factory, and even with that 0.1" difference in the H&R springs, the rear will most likely still be SLIGHTLY higher than the front (to compensate for rear passengers, trunk loads, etc.)
im crossing my fingers for a set of coilovers. as springs dont quite go low enough for me (want the fenders to JUST barely cover the tread of the tires) so these 1" drops just wont cut it. i need about 2" or 2.5".
it also gives me the choice of custom spring rates to fine-tune the ride so its not very harsh. i expect near-factory ride, plus adjustability. coilovers are pure win.
and by swapping out the entire shock/spring assemblies, the OEM stuff will be like new if/when i ever sell it or give it back at the end of my lease.
when i had my 2012 civic, it took companies the better part of 8 months to actually get product out there for suspension. i would expect a good selection to be available (maybe 6-10 brands?) by this time next year.
patience! dont jump on the first thing that comes out. a rushed product is just that. wait for stuff to get reviewed, take your time.
With you for sure... im a coilover fan myself. Custom spring rates on some ground controls is what I have had on a couple other setups.
Springs are cheap and easy though. I dont mind spending a few hundred to get something going from a good company. Everyone has a different opinon but im a much bigger fan of H&R than Eibach or Tien for straight springs.
For me this is my new family car so looking for a 1.5 or less drop.
Anyone know if we need these have adjustable camber or do we need the typical kits for certain drops?
· 2013 Sedan Sport
its mcphearson fronts so it will need adjustable top hats much like nissan 240sx, etc...
older hondas had dual A-arm, so they had either shims for the upper A-arms to push the out, or for extreme camber adjustments, the entire upper A-arm was replaced for maximum adjustment.
and as far as coilovers, i mean true threaded body shocks.
ground control is just an adjustable height spring sliding over whatever shocks (oem, aftermarket), that if improperly adjusted (lower than 1.75") will still put the shock in a non-operational area of stroke, no matter what brand they are.
true coilovers (BC, Megan, Skunk2, etc.) have a threaded body, so you actually change the entire ride hieght, not just the spring.
*edit*
pic of "ground control" adjustable springs vs. K-sport coilovers (not the best brand, but they make my point)
ground control
K-Sport coilovers
now you still have spring height adjustability on the coils, that is your pre-load and you generally want to leave that as is.
for ride height you adjust the perch at the bottom, effectively moving the entire assembly down, not just the spring.
:thmsup:
· 2013 Sedan Sport
waiting for megan coils...springs blow stock shocks - no thanks
right you are sir!
as for true coilovers being overkill? dude. read that quote up there. how about replacing shocks every year? THAT is overkill.
coilovers can last up to 6 years if you take care of them.
and like i said, you can get custom rates if the company is good enough to care. i was going to get rates on my civic only SLIGHTLY stiffer than stock so as not to bottom out yet still be soft enough to drive my 4 y/o twins around. (used to drive them around in a fully drift prepped s14 with 8/6kg springs and full spherical rod end links! ****ed but now everything else is cake lol)
seriously, coilovers are worth EVERY PENNY. :thmsup:
· 2013 Honda Accord Touring
Lowering Springs 2013 EX-L V6
everyone needs to read this afew times - don't be like me and buy springs and then later find out I should have bought coils - cost me 700 or so in labor and wasted $ on springs. Here's the FAQ from the the 8th gen section...
http://www.driveaccord.net/forums/showthread.php?t=41541
so I should initially go with coils rather than just getting for example the Eibach Performance Lowering Springs for the 2013 model when they release them?
this will be my first time lowering on a car and my friends locally have told me to just buy springs. I'm only looking for a 1.5" inch drop at the most, more like 1-1.25", then plan on putting 19" rims on
· Retired from BMW of NA
if you are looking for just a 1.5 inch drop wait for the HFP system. Think about it, when Honda wants you to drop your car they don't sell you springs, they sell you a matched spring and shock (which is called a coil). The stock shocks are in constant stress when they are used with a shorter spring. Some may go years and be ok, but plenty of 8th and 7th gen guys blow in the first year. And not racing, but commuting.So it's up to you.I'm am not some boy racer that want to slam the car, I am 62 but wanted a drop more than a spring, what looks right. Here's my drop on megans for the car I just traded in. It is the perfect height in my eyes: Look at all three - stock, springs and megans:
I am waiting for a matched coil and spring from megan or Tein. Also, a spring is one drop avail - with a coil, they are threaded and you can CHANGE your drop as you move to new areas, raise them for snow, etc. In owning megans for 2 years I adjusted 3 times....to get it perfect for me....
