1 - 2 of 2 Posts
I have a 2000 Accord V6 and it recently starts to make a really annoying squeak. It seems only to happen when the suspension goes up or down. (i.e. driving down the roads and hitting bumps, braking/accelerating hard, and of course when i push the car up and down. Im sure the noise is originating from the front right. Took it to a local shop and got their "courtesy inspection" and of course they found about a dozen things that could cause the squeak. Is there any way to narrow it down?
Does the squeak go away when you drive in wet weather? If so, its probably a suspension part down low that gets wet and lubed by the water. If not, its probably something that stays dry (strut bushing?).
You could get a spray can of silicone lube and start squirting the moving parts on the right front suspension. I would start with the sway bar bushings and end links then move on to other things like the control arm bushings.
1 - 2 of 2 Posts
