1 - 5 of 5 Posts
2013 Accord Sport 6MT
Encoders/Decoders?
Are they not just resistors? So that you don't get hyper-flashing when you install the LEDs as they have a lower resistance compared to a standard bulb. If this is the case, exLED sells them too.
exLED Load Balancing resistor (Braket type) for LED Turn-Signal
That being said, I personally run VLED's Triton system for my signals. Switchbacks up front and amber rears.
VLEDS
Edit: with the Triton system you don't need to splice into any wiring if you don't want to. The only thing that needs to be spliced is a wire to the headlights, if you want to reduce the intensity of the LEDs when your headlights are on. Because I run HIDs, I spliced mine into the HID harness. So I can revert back to complete factory wiring if I want to. In my opinion, you should run this wire as the LEDs are overly bright at night without them.
Discussion Starter #4
Yeah I believe theyre just like resistors except you dont have to do any splicing because its plug and play. Koto you use the decoder or do you use resistors off ebay?
1 - 5 of 5 Posts
