1 - 7 of 7 Posts
Took my 8th gen in for a $30 oil change at the local dealer... I had a b1 code...
They wanted to clean the evaporator core for $79
Cabin filter replacement for $86
Rear pads replaced bc they're at 2mm - $190
Now if that's not a ripoff I don't know what is.
I'll do the work myself
Evaporator core cleaned - $16
Cabin filter replaced - $13
Rear pads replaced - $42
All my wats
$86 for a cabin filter replacement? It takes longer to empty out your glovebox to detach it than to actually change the filter!
It's amazing how cheap cars can be when you can do the work yourself. $30 for an oil change isn't too terrible, at least.
Elvira
What did you use to clean the evaporator core? Foaming cleaner? Which one do you recommend ? TIA
That's a stealership for ya. $86 to change the cabin air filter? My Honda dealership charged $112 to change the cabin air filter. I recently changed it myself a few months ago for the first time, and even then, it only took about 5 minutes.
Just here for the food
Wowzersssssssssss 190 bucks to replace the rear pads. That's insane. My 'ship charged me I think 270 to replace the front pads + resurface the front rotors. -____- blasphemy! I'm considering changing my rears (pads + rotors) when I put my new front rotors on anyway. Weighing my options for a rear kit at the moment though. Anyway......
Cheers to you for getting those little jobs done on your own and not getting ripped off from your 'ship! :salue:
Discussion Starter #6
1 - 7 of 7 Posts
