1 - 6 of 6 Posts
So I have a '13 I4 EX-L coupe which I bought used from a dealership, at around 23K miles.
Car was serviced while it was in the dealership before I got it. I have done close to 5000 miles, oil life is showing 35% and I am thinking of getting an oil change done.
I had a look at the oil and it seems a little bit dirty.
Anything else I should get done with this oil change ?
Transmission oil change ? I have no information if this ever has been changed so just want to be safe.
Rotate tires ?
Car runs real smooth and no issues till date. It does seem a bit slow off the line though, power seems to kick in after I cross 4K RPM. I drive with ECO off.
Is this something I can ask the service people to look into ? Wouldn't mind a bit more zip.
Tire rotation isnt a bad idea. Air filters and such. Think transmission fluid is about due, but refer to the schedule to be sure. Oh and maybe an alignment since youre getting a rotation.
wait till 15%
Discussion Starter #4
wait till 15%
I thought about this but when I checked the oil it was a dark shade of brown, i think.
It has been more than 6 months since I got this car so I thought of getting the oil changed.
Regarding the Transmission oil change. I remember reading in the forums about a full flush versus a partial change, cant remember what the partial oil change is called. Which one should I go with now ?
I have the 2013 as well. I did my transmission fluid at 30k. The fluid still looked good but its inexpensive to do yourself and it can't hurt. The manual for the car calls for a fluid drain and fill, not a flush. Thats what I did. Took nearly 4 quarts of the Honda CVT fluid. The process is pretty idiot proof.. Drain, fill. Check the "check hole." Any excess fluid will drain from the check hole. Done.
Oil color is not a good indication of remaining oil life. Waiting until 15% on the MM shouldn't be a problem. I'd wait until that time then go ahead and do CVT service. It's only a drain/fill, and not neccessarily indicated in the manual, but a good idea every 30k or so. Cheap insurance, and if you do it yourself (and save receipts!) it won't hurt the wallet much.
1 - 6 of 6 Posts
