Hey, I have a 2005 accord coupe v6 6 speed has made this noise since I purchased it. Here is the video of the noise(turn volume up) http://youtu.be/a3D6D9mX7g8
You can hear the noise in neutral with the clutch out and the noise goes away when you push the clutch in. I first thought it was the throw out bearing squeaking but someone said if the noise goes away when the clutch is pushed in it could be an input shaft bearing. Also, my steering wheel shakes in first and second gear while accelerating(only) and I thought this might be linked to an input shaft bearing as well. Any input is appreciated. Also, does this need immediate action or is just an annoyance? Thanks.
