Good day - I am a new owner of a 2015 Honda Accord CVT sport model. I recently came from an Acura TL 4th generation model. The question I have relates to tire pressure. I just checked my tire pressure and the front drivers side tire was set at 41 psi. All 3 other tires were set at 35 psi. I checked the tire pressure cold. What do you owners set your pressure at for the best ride?
Thank you for your time - glad to be a Honda Owner
Welcome to the forum and congratulations on the 2015 Sport.
Someone at the dealership didn't do too good of a job of pre-delivery inspection. That 41 PSI is usually performed at the plant and left high upon delivery. Some think the high PSI is so that during transportation the car doesn't "bounce" around on the truck. Eh, could beee!
You'll probably need to reset the TPMS (tire pressure monitor) if you didn't already after lowering that one PSI tire.
40 harsh ride. No compliance of the tire. Longer stopping distance due to smaller contact patch. Hydroplanes WAY to easy at that pressure too.
33 is recommended (I think this is right for 2015) as seen on the doorjamb sticker. But, I have run at the recommended PSI and found a little less MPG (as measured by the computer) on my usual route. It also felt TOO compliant and "wobbly". Not dangerous wobbly but not to my liking.
35 all around is what I run and consider it a good compromise.
YMMV but you'll need to play with the PSI to adjust to your liking.
