I have a '00 Honda Accord EX 4cyl and for the past year I have had the code P0740 but it has never caused any issues. Recently I have slowly had some issues with my reverse, mainly on inclines, when I go into reverse it will move a couple of feet and then act like it is in neutral until I shift to another gear and then go back to reverse and then its fine and will reverse with no issue. I took it to have a diagnostics done and they are saying it will cost around 2k for a tranny overhaul. The only thing they really mentioned was the torque converter being replaced. I am sure most of the 2k is in labor costs as they said it would take 3-4 days to be complete. When I looked up the code it said it could either be the Torque converter clutch (TCC) solenoid or the wiring harness is loose or damaged. Has anyone else had any experience with this code or issue?
