1 - 3 of 11 Posts
I will probably just hand tighten it like when I changed the oil. I really doubt the dealership torques drain plugs when they service either. However, there is the benefit of being right on with a torque wrench.
As long as the drain hole on the CVT is threaded with steel like the actual steel drain plug everything should be ok with hand tightening. I doubt the drain hole is aluminum threaded. Can someone verify?
1 - 3 of 11 Posts
