Installed the heated/power/blinker side view mirror. Action crash name brand from parts geek, not an endorsement just specifiying the install.
1) Cut the harness off from both sides and spliced all lines for the connections.
2) Driver's side plastic grommet in the door is very difficult and requires a hole to be drilled or a slot pin to be used for the pass through. You could always route (blinker power source) it on the bottom of the door, but if you are a perfectionist......
3) Multimeter is a plus, I used it for checking voltage
Drivers mirror
Mirror Door
Power
yellow to blue/white
white to blue/black
blue to green/white
Heat
black to forgot to write it down
**not a repeat, yes 2 black wires and I forgot to write it down x2**
Turn signal
Pink
Purple
**route power from the turn signal, recommend the rear**
**I choose to ground on one of the 3 screws holding the mirror in place**
Passenger mirror
Mirror Door
Power
black to green/white
yellow to red/white
white to red/yellow
Heat
pink to black
purple to orange
Turn Signal
pink
purple
***yes my passenger side had 2 pinks/purple wires***
Drivers mirror
Mirror Door
Power
white to blue/black
blue to green/white
Heat
Turn signal
Pink
Purple
Passenger mirror
Mirror Door
Power
yellow to red/white
white to red/yellow
Heat
pink to black
purple to orange
Turn Signal
pink
purple
