Are these coax alpines? If so I would disconnect the stock tweets, well, because they ****. It's easy to do (at least in 7th gen). Just get a flat blade under the front of the grill and pop it up...pull it out and press the retainer on the wire plug and pull it out. Stuff the wire back in the dash and put the tweet/grill back on. If these are the component Alpines...pull the stock tweeters out and trim back the tweeter mount opening and sqeeze the Alpine tweets in (must be wired from the crossovers) and use a bit of hot glue and you're golden. I am running just eh 6.5" drivers with no tweeters (waiting on wiring kit) and it still sounds better than the stock speakers.
