Hey everyone...
I am worried here - I replaced my rear pads today on 08 Accord, and this was my first rear brake job. I have replaced front brakes on various cars many times.
I used a C-clamp to retract the pistons into the calipers, as I didn't realize that these were supposed to be threaded back into place. It wasn't easy, but they did retract eventually. They turned as I retracted them, but I don't think they were turning the whole time.
So what do you think? Did I do some sort of damage to them? I have taken it for a couple of test drives, and I didn't notice any difference in the braking performance, but I did notice that the rear brakes smelled kind of hot after a 2 mile drive at 60 mph with a couple of somewhat hard stops. The parking brake seems to work, but I can't tell if it is as strong as it was to begin with, since I rarely use it.
Finally can someone explain how this rear piston works? It seems like it can't turn under normal driving conditions, since the grooves in the piston face seem to engage with metal "nubs" on the back of the pad. So as the pads wear, the piston extends, and you have to retract it by pushing and turning (or is it just turning)? This seems odd, since if there is something threaded inside the piston, wouldn't it run out of threads eventually?? Sorry if this doesn't make sense - I am having a hard time explaining it! I am assuming that this turning motion is somehow related to the actuation of the parking brake? I noticed that the actuation of the PB seems to rotate an arm on the back of the caliper and the piston extends and retracts slightly.
Thanks for your help and understanding!
