Hello everyone.
I have a 2001 Honda Accord Ex Vtech, F23A1 with a bad upstream O2 sensor. I have the new Denso sensor. I went to put Mouse Milk on the sensor today so I can loosen up what is certain to be a tough removal and discovered my sensor is inside of the exhaust manifold. About 1/2 of the sensor is inside the manifold. I cannot access or see the hex bolt part of the sensor. It is buried in the manifold.
All of the videos online show the sensor completely outside of the manifold up to the bolt. Is this normal? I cannot get the sensor removal tool I purchased inside the rather small hole in the manifold nor can I get a standard socket in there. How do I get the thing off? DO I have to remove the manifold? There seem to be 3 bolts on it, all rusted but saturated with mouse milk now. I cannot cut the wires as this is my ONLY car and it needs to be driveable should I have to take it in to be repaired but I should be able to do this job on my own.
The engine block was replaced about eight years ago because the shop allowed carbon to get into the engine when doing a repair. Is it possible they put a non-standard manifold onto it? Every picture and video I have seen shows the O2 sensor mounted on the outside of the manifold ...
Ideas?
OK. So my cousin said it was the exhaust manifold but it may be the header? The O2 sensor that needs to be replaced is in the engine compartment, not near the cat. I may have the terminology incorrect in my above post. Cousin works on US cars and he seems to be confused ....
Ideas?
