Hey guys, I'm going to be installing my gear pretty soon... does anyone have experience doing this?
I browed through hundreds of posts, but never found a true guide to wiring a Viper 5301 remote starter with a CANMAX 400. I pieced the install information together and came up with this.
Does this wiring look good to you?
CANMAX 400DEI --> ACCORD
20-pin connector --> 7-pin connector (Behind key cylinder)
PIN 3 (tan) - CAN Low --> PIN 3 (blue) - Imm. Conn. (white)
PIN 4 (tan/black) - CAN High --> PIN 4 (pink) - Imm. Conn. (white)
PIN 14 (violet/white) - IMM. Data --> PIN 6 (lt. green) - Imm. Conn. (white)
CANMAX 400DEI --> VIPER 5301
4-pin D2D harness --> VIPER 5301 D2D connector
VIPER 5301 --> ACCORD
Primary (H1) 12-pin connector
H1/2 (red) - 12V input --> H3/5 (red) - H3 connector
H1/5 (black) - Ground --> Ground
Heavy gauge (H3) 8-pin connector
H3/1 (pink) - Ignition 1 (out) --> Ignition 1 (blue) - Ignition harness
H3/3 (orange) - Access. output --> Access. 1 (orange) - Ignition harness
H3/4 (violet) - Starter output --> Starter 1 (yellow) - Ignition harness
H3/5 (red) - Ignition 1 (in) --> 12V 1 (white) - Ignition harness
H3/8 (red/black) - Acc. start. in --> H3/5 (red) - H3 connector
Remote start input 5-pin connector
PIN 1 (black/white) - Neutral sfty --> Ground
PIN 3 (brown) - Brake shutdown --> Brake (lt. green) - Brake pedal switch
PIN 5 (blue/white) - Rear defog --> Rear defrost (black)Fuse box green
Any help appreciated!
Judge
Judge
