Just replaced the starter on a '09 Accord EX, 2.4L. When I first turned car on after the replacement, everything fire up great. Only issue is the VAS light and check engine light came on. Pulled the code and it was a P2135.
I did a little googling and decided to disconnect negative terminal from battery for a min to reset it in case it was a faulty signal. Reconnected and both VAS and CEL went away.
My wife and I drove prob 5 miles in the car to a friend's house, no issue, then on the way back VAS and CEL popped up again. Got home and pulled the code again, and this time it was a P1129. I noticed when we pulled into our driveway and shifted to park the engine was idling at a higher RPM (1500-2000)
My first thought was perhaps I didn't plug in a sensor fully...but I'm pretty sure I plugged everything back in and spent a little more time making sure the clips were all snapped into place.
Has anyone else experienced this? Anything I should be taking a closer look at?
