I've got a 2009 accord ex k24 with a salvage motor. Picked it up and while I'm checking over everything I'm noticing the vtec spool valve doesn't have every port plugged in. The passenger side port pointed directly up is plugged in however the port closer to the driver(also points straight up) isn't. I'm almost certain that the spool valve with 2 cylinders at the top is the correct system for the k24 09 accord however I'm not certain every port is used. Any information regarding the issue is appreciated.
