Did you scan for any ABS codes? Codes would help you pin point the issue. Either way, the issue is VSA related.
Edit: Get a scanner that is known to be able to scan for ABS codes. If no codes are present, it could be a VSA module on its way out or maybe a bad wheel speed sensor.
You can also take a look at this post to have the car do a self diagnostics.
How to Clear ABS & Read ABS codes, Clear VSA light - AcuraZine - Acura Enthusiast Community
3G TL Problems & Fixes - How to Clear ABS & Read ABS codes, Clear VSA light - I recently had to replace my wheel speed sensor and came across a procedure to clear the ABS codes and the VSA light. In my particular situation even after my sensor was fixed I still had the VSA indicator light and...
acurazine.com
