I fixed my Ignition Switch today.
I ordered an entirely new distributor from China-zon. Hopefully I won't have anymore leaks with this one, but I'm going to rebuild the OEM unit I took out with a seal kit whenever I have time.Keep an eye for the leak, there's an o-ring AND a shaft seal that can be replaced on the v6 dis. The 4cyl seal I guess is harder to do. I had to do the shaft seal a few years ago and it stopped my dribble after realizing the o-ring wasn't the problem.
So I was working on it today and in the process of removing the pin that holds the shaft in place, one of the ears on the shaft broke off. Is it possible to replace the entire distributor shaft? I do not see the part online. I have found every other component of the distributor except the shaft.Keep an eye for the leak, there's an o-ring AND a shaft seal that can be replaced on the v6 dis. The 4cyl seal I guess is harder to do. I had to do the shaft seal a few years ago and it stopped my dribble after realizing the o-ring wasn't the problem.
The gear is separate from the shaft. It's held in by a pin. I was hammering away on the pin with it in a vise and it slipped and chipped it off.Man that blows, maybe you can get that out of a junkyard one. Can you take the shaft out pretty easily? How did that break, it seems like it's pretty solid with the whole thing
It appears the gear isn't sold separately. Apparently GM distributors are, because they kept popping up in my search results.
I'm not going to stress it. I know now that I just need to get someone else to hold the distributor while I hammer it out. I'll have to do the same job on my 4 cylinder car. If the aftermarket dizzy that I purchased fails, then I can just take the gear out of it and install it into The OEM after I reseal it. Or like you said, find a junkyard one. I think one of my co-workers has a stash of Honda distributors from when he used to own one that he might give me.
Good to know, thank you! I marked the correct orientation befor disassembly. Making mistakes is the best way to learn.I have bought a gear off eBay before. A few years ago put the dang thing in upside-down.. went to start it.. ping!!. Haha Live and learn..
NEW HEAVY DUTY REPLACEMENT TEC DISTRIBUTOR DRIVE GEAR FOR ALL HONDA ACURA | eBay
Find many great new & used options and get the best deals for NEW HEAVY DUTY REPLACEMENT TEC DISTRIBUTOR DRIVE GEAR FOR ALL HONDA ACURA at the best online prices at eBay! Free shipping for many products!www.ebay.com
I bought a Walker Aftermarket Cat for my Honda. About $600. It didn't get stolen, it wore out and turned on the check engine light.Since it's nearly 3 AM.....yesterday I found out just how much damage the catalytic converter thieves did......$2,950 dollars worth of parts are needed!
I've actually jotted down about 10 numbers from Craigslist I plan to call on tomorrow. However, aftermarket may be a better bet.
They wear out? Seriously? I honestly did not know.I bought a Walker Aftermarket Cat for my Honda. About $600. It didn't get stolen, it wore out and turned on the check engine light.
Yes, Mine was rattling also. There are numerous articles online about cats going bad on Accords.They wear out? Seriously? I honestly did not know.
I visited the Honda shop and found out I only have the sensor on the cat to worry about. They printed me out a parts schematic and I printed out some pics of the damage for the report I am putting together for the police department.
IMO, it's just generalized info as CATs go bad on all cars. Biggest reasons why are due to burning oil, blown head gaskets, or other contaminants are getting to the CATs causing to fail.There are numerous articles online about cats going bad on Accords.
Thanks. Now I don't like my filter choice. I watched a Youtube last night of 6 filter comparisons. The Mobil 1 was outstanding except for one thing. The spring tension on the bypass was absurdly too high, rendering the bypass function pretty much unusable. None of the others needed near as much force to open. I'm not exactly worried about it, but next time I'm going with the Wix, or a Honda.I think that "tapping" noise is pretty common. Mine does that and has for at least 100,000 miles. Local Honda shop told me "it's normal."
Lrobby.......congrats on doing your own oil change.
I love doing my own oil changes!
