You're one of the lucky bunch.Hmm. I'm not too sure what they check exactly as this is my first car. But its a yearly thing.
yea, i was actually just looking at that.. looks like they DO check lights.. but how thoroughly? hopefully they just check that they turn on. i mean there shouldnt be any problems right? or all these civics and corollas with HIDs in their reflectors blinding everyone would fail every year..
+1 MD is easy to get away with (except if you have a exhaust system with a 2" tip).You're one of the lucky bunch.MD inspections are generally a "once and you're done" deal. Frequency varies by state, e.g. PA also requires annual inspections.
NY they check headlights because people like to ride around with 15000k deep blue, sometimes 30000k purple, and one time I've seen GREEN HID in halogen housings that are really unsafe on the road. Along with that, they have on the fog lights and other misc. lights they've added to their car [Ricey]yea, i was actually just looking at that.. looks like they DO check lights.. but how thoroughly? hopefully they just check that they turn on. i mean there shouldnt be any problems right? or all these civics and corollas with HIDs in their reflectors blinding everyone would fail every year..
ive seen people with purple lights, actually saw one last night.. stupidest thing IMO.+1 MD is easy to get away with (except if you have a exhaust system with a 2" tip).
VA is more difficult to pass (every year). As soon as they sit in, they will check all the lights on the dash (CEL, SRS, ABS, etc). They check that all your accessories work (lights, wipers, horn, etc) then raise the hood check for leaks, and go under the car to check for safety (brakes, lines, hoses, oil pans, etc). It's like getting an full inspection for $16.
Depending on the inspector, they will try to fail you for "ride being too low", "exhaust too loud", "too much lighting", "oversized wheels", ... random stuff.
Then the emissions test is to check for "emissions". It's either like a dyno type test where they run it on a diagnostic ramp or they plug a OBD scanner into your car and something in the fuel tank to check for CEL codes and emissions level depending on your make, model, and year. $28.
I've seen your from pics and your youtube vid, you're fine. Just do not change it to some deep color.ive seen people with purple lights, actually saw one last night.. stupidest thing IMO.
so i shouldnt have any problems with my HIDs right? i mean i do have a retro on my lows with 4500k, but my fogs are just regular housings with 4300k.
i probably wont. if anything 5000k is the most i would go up to.I've seen your from pics and your youtube vid, you're fine. Just do not change it to some deep color.
Safety Tests
Safety inspections typically take about 12 minutes. In a safety test, the inspector looks for or tests 14 key areas:
1. Visual Overview
Certificate of registration
Vehicle Identification Number (VIN)
License plate(s) Decal
2. Brake Tests
Parking brake
Service brake
3. Exhaust System
Exhaust system components/Muffler
Visible blue or black smoke
4. Steering and Suspension
Steering wheel and box
Suspension/front end
Springs
Shocks
5. Horn
Sound horn to test for adequate signal
The horn must be securely fastened to the vehicle
6. Glazing, Glass and Windshield Wipers
Windshield
Windshield wipers and washer
Windows
Tint
7. Rear View Mirror
Rear view mirror
Mirrors (General)
8. Lighting Devices
Head light aim
Hazard lights/directionals/stop/reverse lights/and license plate light(s)
Reflectors
9. Tires and Wheels
Tires
Wheels
10. Bumper, Fenders, and Fuel Tank
Bumpers
Fenders
Floor pans
Fuel tank
Vehicle Frame or Unibody
11. Altered Vehicle Height
12. Seat Belts
13. Airbags
14. Fuel Tank Cap
and i got it done 3 days after installing a 6000k hid kit into factory halogen reflectors and passed fineEmissions Tests
Massachusetts uses two types of emissions tests: On-Board Diagnostic (OBD) for most vehicles and Snap Acceleration Opacity for heavy duty vehicles that are not equipped with OBD systems.
The Massachusetts Vehicle Check on-board diagnostic (OBD) emissions test is designed to ensure that your vehicle keeps running as cleanly as it was designed to run, which in turn protects the air we breathe.
The OBD test typically takes about 3 minutes. The inspector connects your vehicle's on-board computer to an analyzer in the station, and then downloads engine and emissions control data. The analyzer checks several OBD system functions
Communication. Does your vehicle’s OBD system communicate with the analyzer?
Readiness. Is your vehicle’s OBD system “ready” to be tested?
Diagnostic Trouble Codes (DTCs). Why would the OBD system turn on the Check Engine light?
Check Engine Light. Is the Check Engine light (sometimes labeled as “Service Engine Soon”) turned on?
