1 - 7 of 7 Posts
Hello all I got a deal on some Federal 595-RR tires they are 255/35/19 but they do run large some measure larger than a 265 tire and close to 275 even. Therefore these tires won’t work in stock 19x8.5 wheels.
I was thinking 19x9.5 in a 35 offset. I have stock suspension right now but may do Eibach springs. Not sure which offset would work.
Appreciate the help!
Tire Wheel Automotive tire Tread Synthetic rubber
Discussion Starter · #2 ·
Oops just realized I posted this in the 9th generation instead of 10th. Can a mod move this to 10th gen section? Thanks !
· 2015 accord sport
Appreciate the help! View attachment 545163
actually those tires will fit on the rims you have but on the car they may or may not rub, I know 245/35/19 tires will work without rubbing, good luck
they are nice tires
they are nice tires
Thanks. I am running 245/40/19 winter tires now without issues.
Reactions: johnk_11
Please post pics when you have these on. I really want to run a wide fat tire setup too.
I won’t have them on until spring time they will work though they measure 10.1 inches my other 255 tires the Toyo T1R are 10. That 0.1 inch difference should be negligible when putting them on an 8.5 inch wheel although I may get a lighter set of rims in the 20 lb region since the factory rims weigh 31 lbs a pop. Shaving off 10+lbs of rotational mass on each corner will make it feel like a different car.
Reactions: kona900
1 - 7 of 7 Posts
