1 - 17 of 17 Posts
2018 accord exl with 17 inch wheels.
Running michelin Premier AS 225/50-17 94V.
Dealer says 32 lbs, tire store says 34. Any suggestions?
Set it at 34 and in a couple of weeks when temps change it will at 32.
NOT your average Joe
2006 Accord EX Sedan, 2.4ℓ & 5-spd Auto
What does the placard on the door jamb say?
EXECUTIVE SUMMARY FROM MODERATOR
This is what we got so far....
Dealer: 32
Tire Store: 34
Door Jamb sticker: 32
Reactions: Mikeh and 2Accordz
Does 2 psi make a crazy difference? I know sometimes pressures are also found on the tire. I would go with the tire recommendation at that point.
33 ?
Tire pressure change all the time, temp of the tire when cool parked, temp when driven for 20 min., temp when driven all day, then there’s the air temp. 2 or 3°, is subjective, go with dealer.
What I have seen on the tire has always been the max pressure. Not a good idea to use that. The same tire can have different recommended pressures on different vehicles.
I'd also say that 2 psi back or forth don't make or break your day.
2018 Touring 2.0T
I tend to inflate about 10% over the door-jam recommendation on the presumption that this results in less sidewall flexing and thus cooler running here in the South Florida heat. Am I doing something dumb? Enlighten me, o gurus.
Luddite - I do about the same thing in the Aridzona heat, and, for the same reasons. I've done this with EVERY vehicle I've ever owned (since the early 1960s) and have never found a reason to stop doing it.
- Jack
1 - 17 of 17 Posts
