241 - 248 of 248 Posts
I believe someone posted this earlier but reporting mpg is only helpful when we know things like temperature, terrain, driving mode, driving style, etc in addition to mix of city/highway, average speed, degree of heavy traffic, etc.
ive gotten 75/80 mpg in city over a 5 mile run but it was a slight downhill in 45 degree weather at speeds under 35 mph with less than a handful of lights in eco mode...
My commute driving is 90% highway, relatively flat over 75 miles with an average speed of 40 mph due to congestion in the New York metro area. My mpg range in temperatures between 17-59 degrees has been a low of 45mpg and a high of 64mpg as reported by the fuel meter. My meter seems to under report by about 1-1.5 mpg lower than actual. I drive in eco mode, and use the regen paddles every now and then.
It seems the mpg killers as others have posted are:
1) speeds over 62-65 mph. 35-55 is this car’s sweet spot. It seems any sustained bursts over 65 drop my mileage a bit.
2) temps below 38degrees..it seems there is a more noticeable drop. When temp fluctuates between 20-32 degrees the drop doesn’t seem as severe for my driving
3) terrain...flatter is better...;)
It's becoming very apparent who drives on the freeway more and who doesn't based on their mpg.
... not to mention those who live in "hill country" vs. those who don't. I live in an area with lots of hills. In fact, most of the routes I drive add insult to injury by having on ramps that are uphill runs with fairly aggressive grade. Even so, I'm clocking in at 43 mpg mixed driving. This is after three months and ~1200 miles.
re: the throttle response discussion, my anecdotal input is... econ < normal < sport (where response is least to greatest). Funny thing, I've had it in econ and it won't even "idle" over the lip into my garage when I'm off the accelerator, whereas normal climbs over it fine. Evidently it doesn't like to give the electric motor that little bit of "fake idle" in econ to just roll when off the pedal. Just my personal experience, although I can reproduce it at will.
I just leave it in normal and drive the car... if I know I'm taking it out to the twisty parts, I'll put it in sport - that's more for the suspension algorithm than anything else, although it does work harder to keep the battery at full charge.
All said and done, the HAH is a constant torque curve from 0 to 4k rpm, so it's not going to react the same way as a traditional ICE setup with auto trans downshift / kick down on WOT. If you wanna go fast just ease into the throttle and let the computer take care of the current draw you need. Otherwise you're just going to frustrate yourself by trying to treat it like something that it isn't - it's just a change in habit, for me it's been easy to get used to and frankly this car is quick and fun to drive.
... It seems the mpg killers as others have posted are: ...
I've reported on my Monday commute before, since it is long and consistent enough for comparison. It's 44 miles each way, starting with suburban highway, then rush hour beltway, then rural highways.
In summer, I'm typically over 50 mpg. Last week at 22° to 25° it was 41.5 mpg. This morning it was 34° and I got 46.5 mpg (all of these numbers are before applying a 3% adjustment for trip computer underestimation). [Edit] In the drive back, it was 49° and I got 49 mpg.
So below 35°, it seems to be 1 mpg lost for every 2° drop. The drop seems to begin from about 50°.
I've repprted on my Monday commute before, since it is long and consistent enough for comparison. It's 44 miles each way, starting with suburban highway, then rush hour beltway, then rural highways.
In summer, I'm typically over 50 mpg. Last week at 22° to 25° it was 41.5 mpg. Today it was 34° and I got 46.5 mpg (all of these numbers are before applying a 3% adjustment for trip computer underestimation).
Jeff, yes you’ve been detailed in reporting your mileage under conditions so it’s helped for sure. Mine was a general ask of people so folks that are perusing the board prior to buying a HAH have a sense of real world performance to inform their purchase decision. Your input certainly helped me in buying my 2019 2 months ago.
typical driving speeds are 35 - 40 mph in town. I haven't seen that high of mpg displayed before or since so I was just wondering if my display was accurate or not.
It’s hard to say. Could depend on the length of your trips, stoplights, how aggressively you accelerate, how cold or warm the battery and/or engine is, etc. The hybrid powertrain is at its most efficient when it’s had the opportunity to warm up and when outdoor temps are at or above about 45, among myriad other factors. A short 3.7 mile trip from my house to Walmart might yield mpgs in the 30s but on the way home in the 50s. Perhaps you could try manually calculating your mpg. The computer understates my per tank average by about 1.5 miles/ gal. I’ve averaged about 48 over 9900 miles.
I think where people are getting hung up is on category of transmission... the ratio can be single speed fixed or you can have multiple gears... in the case of iMMD with "eCVT" the gear ratios displayed are fixed... what's "continuously variable" is the source of the electric power driving the electric motor with the exception being straight clutch lock up between the ICE and wheels under specific cruise conditions... based on all the diagrams presented, there's no evidence of a traditional CVT which is continuously varying gear ratios between either the electric motor or ICE.
tl;dr yes it's a transmission, but regardless of ICE lock up or varying source of electric power between battery and ICE/generator, the gear ratios used are always fixed.
2018 accord hybrid touring.
Over 50f -82f, no ac 52 going to work 48 coming home(elevation change)
Under 50f with winter tires, 38 going 32 coming home.
Second winter, second summer...
Crazy how bad of a hit cold temps , winter blend, soft sticky Bridgestone Blizack tires.... all affect the mpg so much!
Sent from my SM-G975U using Tapatalk
