Question for the experts...
I have a set of wheels that I am considering using for a winter wheel/tire setup. I am confused about one thing about the specs of the wheels compared to the recommended wheels from The Tire Rack... the wheels I have are 17X7.5 with a 42 offset and 5.94" backspacing. However, when looking at 17X17.5 wheels for the Accord, most of the wheels with the same 5.94" backspacing are shown as having a 45 offset. This is not consistently so, and some of the other wheels with the 45 offset show a different backspacing.
Shouldn't wheels in the same width and with the same backspacing have the same offset (and vice versa)? Since the offset is measured from the midpoint of the wheel across its width, the backspacing should be the same with the same width wheel and the same offset. It seems to me that the only way you can have differing values is if the wheel is slightly wider or narrower than the spec. Or, of course, measurement error.
Any thoughts?
Any thoughts?
