1 - 20 of 51 Posts
Acc-car
Detroit, Michigan
Hey guys!
My '14 Accord Sport popped up the wrench and the A12 code yesterday.
Planning to do the oil change with Mobil 1 EP and Honda filter, air and cabin filter off College Hills Honda (hope that is the best place for parts?)
Question is : do I change the CVT fluid out now, or wait for the MM to show the code for it?
The car has 27820 miles on it as of today. I'm in Michigan, 30 miles a day (majority highway), some short trips in the winter and I like to step on the gas hard and play with paddle shifters once in a while.
Factory CVT fluid is still in.
What do you all recommend?
Searching! This question comes up often. Good write-ups here. Several have changed it early- before the MM. Most just change it when the MM pops up. No issues.
Take a look at my signature, and you will get an idea of what the MM will tell you. I drive mostly highway too, 125 miles round trip M-F.
How long do you plan on keeping your car? Repairs don't look bad at all for 173K miles.
I've been changing my CVT fluid every 30K just because. I might be wasting money doing this though... Are you doing the 3X drain and fill every 3rd CVT fluid change?
It seems like MM will suggest CVT fluid changes around the 50k mark. It seems pretty darn easy to change, so my plan is to do the changes around the 40k mark. That's about every 2 years with the miles that I put on the car.
No! The CVT does NOT have a torque converter where some of the old fluid would remain. Hence, no need for a 3x3 drain and fill on a CVT transmission. One drain should remove 3.7 quarts of fluid- which happens to be the stated capacity of the CVT transmission.
EDIT: I WAS WRONG. PLEASE SEE POST #19 FROM MEMBER @hisoka7922
MY APOLOGIES FOR THIS.
-8427 at 105K? Forget to reset MM? Also I don't see the valve clearances were checked. Mine will pop that code next time. Did you decide not to get that done? Anyone know how much that runs at a dealer?
I plan to keep it until it dies lol, and when that happens I will probably replace the engine with a rebuilt. My previous Accord ('02) gave me 406K miles haha. I know, I feel that I have been pretty lucky so far.
No, I take it to my local Honda mechanic and I'm pretty sure he just does the drain and fill. For my next one, I plan to do it myself going forward.
I forgot to write down the mileage and even the date on my service manual, and took a guess at when I did that oil change, however, when I left work yesterday, I re-did my calculations, and it should be something like 114K or so. I'll update later on when I get a chance to see the new number I wrote down. No, I didn't forget to reset the MM, I am very adamant about resetting it after I do the work.
I have only had the valve clearance checked once, which I believe was at the 107K mark and my mechanic said they were fine and didn't need adjustment. When I check my manual, I will add that to my signature. I don't plan on doing it anytime soon though, since he charged me like $100 for that lol.
Reactions: SOLIDSNAKE
jumping into a thread, hope it's on topic enough.
I am just changing it every 40,000... and as I approach 80,000 let me ask this:
I did a simple drain and fill at 40,000 ...
What do you guys think at 80,000, drain and fill?
Or the extreme 3x drain and fill over a short period to accomplish a 82% full change out, or whatever the calculated % is......????????
Read post #8 in this thread.
My question is why not just go with the Maintenance Minder? I owned a 2000 V6 Accord Coupe and the transmission failed at 93,000 miles. Honda extended the warranty to seven years and 100,000 miles and replaced it for free. However, the automatic in my 07 Fit runs just fine and no one on the Fit discussion boards have had automatic transmission problems after driving a lot more than the 86,000 miles we have on our car. Honda has invested a fortune in their CVT technology and I believe that if a problem arises they will extend the warrantee to cover any manufacturing defects that might arise. On the other hand, if you just like replacing the fluid more frequently for peace of mind, I'm sure Honda dealers, independent mechanics and part's supply houses will be happy to sell you their services and products.
New to this forum thing so sorry if this is the wrong thing to ask, but i have been reading into doing this as i just hit 40k. Have you been using the honda fluid or amsoil? I am leaning towards amsoil but any advice helps
I just have my mechanic use the Honda brand. I don't know anything about Amsoil. It's a special fluid called HCF-2, so just keep that in mind.
Amsoil is a third party company that sells fluids. Lots of people swear by the quality and durability of these fluids. I'm sure that you could use either the Honda Fluid or Amsoil and your CVT would be just fine.
I plan to just use the Honda fluid, its available around $10 per quart via my dealer (would need to buy 4 quarts), and the Amsoil is around $14 and I would have to order it.
I could swear I read that it does have a TC but, if I'm wrong, just how can you come to a stop with the car still in gear? Where does the slippage occur?
Edit: I looked in the Honda parts eStore and one of the breakdowns in the transmission section was "Torque Converter Case"!
This is incorrect. I recall it should be 8 quarts but unsure so I checked the CVT fluid change manual.
The manual states:
Continuously Variable Transmission fluid capacity:
3.5L(3.7 US qt) at change
7.6L(8.0 US qt) at overhaul
That also matches my experience as the fluid still look really dark when I did the second drain.
Manual is attached for whoever is interested.
The manual states:
Indeed you are correct sir. Thank you for pointing that out. I will update my earlier post.
Apologies for the error!
1 - 20 of 51 Posts
