GaudyJust came across this on Facebook. I would throw this on in a second.
The tilted wheels is because of camber and these cars are on airbag so once you lay frame the wheel will tilt in so it can be more lowAlright, someone please educate me. What is up with the tilted wheels? I have been seeing these locally of late, but in most cases either front only or rear only. How do the tires rotate? What is this thing called? Thanks in advance.
P.S. Make sure you perform a ladyboy check.
Mick
Is that the motto of the model with the red car? lolless is more.
they have camber so that the wheels take corners better, your car will basically whip around the corners and pickup speedThe tilted wheels is because of camber and these cars are on airbag so once you lay frame the wheel will tilt in so it can be more low
