1 - 1 of 1 Posts
Vendor
If your vehicle was NOT in an accident and the light came on:
f the airbag light in your vehicle just turned on without an accident, there may be an issue with the airbag system computer, or there may be a bad component within the airbag system. If your vehicle has NOT been involved in an accident, we recommend taking your vehicle to a body shop or collision shop to have it scanned to see what codes are coming up. It could be a bad seat belt or sensor.
If you have a bad, damaged or deployed (locked) seat belt, send it to us for repair. Start Your Seat Belt Order Today!
(39) Airbag Light Just Turned On One Day? - www.MyAirbags.com - YouTube
Does MyAirbags sell replacement airbag modules?
(39) Do you sell Airbag Modules? - Airbag Control Modules Replacement - www.MyAirbags.com - YouTube
Yes, we do sell replacement airbag computer modules.
  1. We recommend that you use the part number that is on top of your module to locate the replacement module. When you purchase a used or new airbag control module it may need to be programmed/configured to your vehicle.
  2. Search our OEM SRS Airbag Modules Ready To Ship
When calling to order a replacement airbag computer module, please be prepared to give our customer service tech representatives the original module part number. Once we have the original module part number, we will be able to verify if we have the module in stock.
What if I’ve already purchased a new or used airbag module replacement?
(39) Airbag Light On? - Already Purchased Replacement - www.MyAirbags.com - YouTube
We advise our customers to compare the part numbers of their replacement airbag computer module to the vehicle’s original module; if the part numbers do not match, it is unlikely that the airbag module will work in the vehicle. Also, remember: the airbag module MUST BE FOR THE SAME VEHICLE IT CAME FROM. If for instance, the module is for a 2008 Honda Accord, the replacement must be for 2008 Honda Accord.
Once the replacement airbag module has been correctly installed in the vehicle the airbag light may still turn on. Again, for the reasons detailed above, you need to verify that you have followed the correct steps and that other parts were not from a flood-damaged vehicle. However, if you have done everything else successfully, the airbag module may need to be reprogrammed for the specific VIN of your car by that manufacturer’s dealership. This is why we always recommend that customers send in their original modules from their vehicles since each module is coded for the VIN of the automobile it is in.
Start Your Airbag Module Reset Order Today!
1 - 1 of 1 Posts
