1 - 4 of 4 Posts
Will a 2005 TSX K24A2 engine (auto trans) bolt into a 2004 2.4L coupe (auto trans).
The reason I ask is my friends TSX just got wrecked but the engine is fine.
He said I could have the engine and I would enjoy the extra HP but not if it requires major set-up changes.
If you have a tsx k24a, I'm assuming the tranny has a 6final drive? And you are going to swap, don't let offset motor mounts get in your way. Not saying that's The case. The 2004-2005 Accord/TSX are similar in more ways than the mounts. You should be fine. If you're not going to swap motors, at least swap the head. That's where the power is anyway. Especially since you have k24a4. Make sure to get the ecu.
My friends thought was the head swap but I was entire engine as his has 1/2 the miles mine does and he's a fanatic on treatment his mechanical parts. Plus I have a buyer for my engine if I pull it.
Thanks for the quick reply.
Did you ever do the swap? I have a 2007 accord auto and want to swap in a TSX motor myself.
I have a 2007 Accord with an automatic transmission with Drive by Wire.. I'm thinking of swapping a TSX. motor., I'm pretty sure it'll just bolt up. I'm not sure about things like radiator hoses, exhaust manifold, wiring, ECU etc. Thanks for any help.
1 - 4 of 4 Posts
