1 - 3 of 3 Posts
Need snows - and I know someone selling 16" steel wheels fitted with winter tires for a 2011 Accord sedan. I have a 2013 Sport.
Will the fit? Clear the brakes? Effect the speedometer?
Searched but didn't find the info
No PRND
The LX comes with 16s and I don't know the brakes to be any different so they should fit. Speedometer accuracy will depend on outer diameter of the tire. If its different (which it likely will be) from the outer diameter of the Sport tire, then the speedo will be off. Good news is it will likely only be off by a couple percent at most, therefore it won't really matter.
I have 16 steelies from an '02 Ody on my 13 EX-L
Best way to tell is to go to tirerack and search snow tires/ wheels for an '11 and do the same for yours.
If the tires/wheels are the same then of course they will fit. Cross check what your buddy is selling at TR
IIRC we have a 114x5 bolt pattern which will display in the wheel specs at TR.
If it's local, jack it up and test fit to be sure.
1 - 3 of 3 Posts
