1 - 9 of 9 Posts
I have a 2016 coupe exl I can save like 37$ a tire by going with the 225 width. Any insight??
V6 6MT CBP
They are NARROWER, not smaller in diameter. 225 vs 235, it won't handle quite the same, it will be a little more fish out of water feeling (Not much), but if saving $37/tire is your thing, you will be fine.
Honda Enthusiast
2017 CR2 Sport 6MT CBP
Just buy the tire size your car is designed for. Stop being cheap.
It’s obviously narrower going from a 235 to 225, it is ALSO smaller in diameter which is what the major concern would be like I stated.
Don’t give people wrong information.
V6 6MT CBP
Ok, I'll give you the smaller in diameter, it is a fact. For a Michelin tire I looked up, 26 vs 26.3 total diameter. Like you said, 1% difference. At 75MPH, that's not even 1MPH.
So the point is, you will NOT notice that difference. Hells bells, as a tire wears it gets smaller, so that is negligible, not a major concern.
You WILL notice the difference in handling dropping from a 235 to a 225. That's my point. Take it for what its worth.
To the OP, I'm sure you can find cheaper tires in the recommended size, that will do just fine.
You will most likely not feel any difference but saving $148 will not change your life, either. If anything, the narrow section will cut through snow and rainwater puddles a tiny bit better. On dry tarmac you will have loads of grip in either case.
517171
1 - 9 of 9 Posts
