1 - 15 of 15 Posts
i want to get these for my 13 coupe HFP MSM. i don't want to deal with rubbing or rolling fenders !!! thinking a 245/40/19 tire. i can't really afford to get this wrong so any help would be greatly appreciated. thanks
9th Gen Coupe
not dropped? they'll fit...
its on the hfp suspension but may lower more later, so it will fit now but not if i lower further? i'm now thinking that it might be safer to get the avent garde m510 in a 19x8.5 +35 as they are almost the same and much safer fitment. or the forgestar cf5v 19x8.5 +35(althought i can choose any offset) and they only weight 20#. thought that was pretty amazing but still like the avent garde and velgen design better. thoughts anyone???
9th Gen Coupe
Even after you lower, they'll probably still be fine, if anything, just add a slight amount of negative camber and you'll be fine.
Personally, I'm more of a fan of AG.
hondaofocala.com
Hi Coupe13 - we sell both Forgestar and Velgen wheels and would be happy to assist you with your order!
I am very interested in those forgestar wheels.. I like the very lightweight style they provide. :thmsup:
Former H Master Tech
It won't fit in the front. I'm running 19x8.5 et 32 with a slightly stretched 225/40-19 in the front and I pulled the fenders but still rubs on bumps and tight turns at times. Your .5" wider wheel and 20mm wider tire will not cut it on a lowered accord with the factory camber specs. My wheels poke out 1-2mm from the fenders as is too. The rears will have plenty of room.
You will need to run a stretched tire in the front, run additional camber, and/or buy staggered wheels to make it fit correctly.
edit: just noticed your a coupe. Not sure if the fenders are the same width as the sedan... But what I posted above is based on my test fitting of wheels on my sedan
cant go wrong with forgestar. i have the f14s. theyre not too heavy for 20s. little bit heavier than my winter HFP 19s..
hondaofocala.com
I am very interested in foregestars. What is your specs on wheels, tires, offset?
mine r 20x10.5 all around +17 all around. hankook v12 summer tires. which stretch really good. (mine r not crazy stretched but slightly)
this size may be too big for the 9th gen coupe tho since your wheel base is smaller. maybe with alot of fender work it will work. if i had a 9th gen id prob do 18s or 19s with beefy/stretched tires.
i also have flared front fenders, (by alot. had them repainted) and the rears are rolled flat
Premium Member
with the Forgestars you can customize the offset to your exact need as they are built to order, so really they can sit wherever you want them to
Always time to play!!
You can customize the Avant Garde wheels too its called the M510 Bespoke!! If you don't want to do fender work you will need to go with a smaller tire maybe a 235/35/19
hondaofocala.com
This search for wheels is a pain! I try those sites for fitiment and than I see JPN with 8.5 Et22 and 9.5 et22 and it fits.. I'm like huh?..probably because he's lowered. First I got to decide 19" or 20"! I already know I'll be lowering the coupe. I do like seeing jpn's coupe since ours are the same color.
1 - 15 of 15 Posts
