1 - 3 of 3 Posts
Anyone have a fix for window "creaking" kind of squeaky rubber rubbing sound. I have a coupe and it happens when both windows are rolled all the way up and going over any kind of bump. I was thinking of some kind of lube, but thought I should ask the Accord pros before I hit the auto store.
Thanks in advance!
Thanks in advance!
sounds like your door seal are getting old. a lil grease and you should be good.
http://www.driveaccord.net/forums/showthread.php?t=36460&highlight=creaking
Search is your friend my friend :yes:
Unique
Looks like you need Shin-Etsu grease. This symptom is a common complaint with the 7th gen Accords. Honda also came out with a TSB for this which required the use of "anti-squeak" tape I believe. Do a search...there should be plenty of info on this here.
1 - 3 of 3 Posts
