1 - 16 of 16 Posts
I got a chip on my Accord touring today while on the highway. Can I repair this with the windshield kits or go to safelite company for repair.
Or does this require replacement?
I don’t like the idea of changing the windshield simply due to the fact that some don’t take pride in their workmanship and I’m afraid of further damage. (I’ve had two bad experiences at dealerships)
And the fact that it won’t be like factory.
524036
524037
Turbocharged
The rainx repair kit from walmart will do wonders for chips like that if you use it properly.
Reactions: A1218
2010 Honda Accord (LX)
Reactions: A1218
Honda Enthusiast
2017 CR2 Sport 6MT CBP
Have Safelite fix it. That’s the best way.
Check with your insurance company regarding your comprehensive coverage. This might be a zero-cost fix for you.
Reactions: jjpark
^^^ that. Before doing anything, check with your insurance.
Yep. Many insurance companies will pay for the $50-$75 hoping to avoid the cost of having to pay for a full replacement- which can run over $1000.
Reactions: jjpark
Had safelite repair mine and the results were not what I was told. I just got another big ass chip so I’ll be replacing the windshield soon.
As long as it's not a large crack, you can at least attempt a repair first and in most cases, insurance will cover it.
Premium Member
If it didn't get into the laminate, they can usually repair it.
Have a pro look at it...they use UV lights to cure the epoxy.
That's nothing I'd ever attempt myself.
Discussion Starter #12
Yeah it is zero cost with the insurance. I made the appt today at safelite so I’ll share the results.
Worth a try if it’s free.
V6 6MT CBP
Just keep in mind, the glue or what ever they use will eventually start breaking down. Is that a bad thing? NO.
I have had three of those marbles repaired on my windshield (Now at 82k+) and the next one I will be asking for a full replacement. I have enough road rash that visibility in a rising or setting sun is past my acceptable level.
Discussion Starter #14
It came out pretty decent actually. Barley see a speck from outside if close and looking. And it’s smooth.
Only on the inside you can see the markings a little.
524077
Before and after
524078
524079
I repaired my own when it happened on my F150. It's held up, but your repair is far better. Next time, I'll let the pros do it.
- Jack
An alternative to safelite is an independent windshield repair shop. Had one fix mine and their is no sign that there was ever a problem.
1 - 16 of 16 Posts
