1 - 1 of 1 Posts
04 coupe w/06-07 rear end conversion-19” TSW Sochi- Nighthawk Black,2008 Equinox LS AWD Summit White
Ever since i got my 7th gen coupe four years ago the drivers side wiper spray hasn't worked properly. Last year I attempted to fix it by removing the fluid hose from the tank and blowing it out with compressed air, and dirt/crud came shooting out of it. After that i replaced all the fluid just to be sure.
This worked for about 9 months and then started to act up again. I blew it out again but nothing came out. I inspected the lines under the wiper shroud and blew out only the drivers side line, instead of the t fitting line from the tank like the first time. This did nothing, has anyone else had this issue and if so how did you fix it? It seems to be an odd recurring issue. Ive tried to clean out the nozzle and nothing seems to fix it. Any advice?
1 - 1 of 1 Posts
