1 - 7 of 7 Posts
HK Moderator
Thanks! I have a 2005 Accord 4 cylinder EX-L. I could use a schematic.
HK Moderator
I can't give out my email. I worry about junk mail and spam and malware and viruses.
Discussion Starter #5
DirectWire: 2005 Honda Accord
ITEMWIRE COLORPOLARITYWIRE LOCATION
REMOTE START, SECURITY, KEYLESS ENTRY, ACCESSORIES
12 Voltswhite+front of fuse box, green 6 way connector
Starterwhite/black+front of fuse box, green 6 way connector
Ignitionyellow/black+front of fuse box, green 6 way connector
Power Lockwhite/red-control push-button in driver door, grey 20 way connector
Power Unlockwhite/grey-control push-button in driver door, grey 20 way connector
Turn Signal (Left)brownback of fuse box, green 14 way connector
Notes:
in alternative, in the wiring harness that supplies the rear services, at the back of the driver side kickplate
Turn Signal (Right)blue/redback of fuse box, green 14 way connector
Notes:
Left Front Door Triggergreen/redback of fuse box (high part), green connector
Notes:
in alternative, wiring harness at the back of the driver side wind screen door-pillar cover
Trunk/Hatch Pinpinkfront of fuse box, green 12 way connector
Hood Pinyellow/red (with original alarm)microswitch fixed to the bonnet mechanical lock
Fuel Pumpyellow/blackinertial switch
Notes:
the inertial switch is fixed in the high part, on the metallic bracket, between brake and accelerator pedals
Alternate view
12 VoltsWhite+Ignition Harness
Second 12 Volts+
StarterBlack/White+Ignition Harness
IgnitionBlack/Yellow+Ignition Harness
AccessoryBlack/Red+Ignition Harness
KeysenseSmall Red/White-Green Conn. At The Left Side Of Fuse Box.
Power LockPink/Black-Green Conn. At The Left Side Of Fuse Box.
Power UnlockPink/Blue-Green Conn. At The Left Side Of Fuse Box.
Factory Alarm ArmWhite-At Driver's Door Switch In A Green Conn.
Factory Alarm DisarmWhite/Red-At Driver's Door Switch In A Green Conn.
Trunk Alarm ShuntSee Diagram
Parking LightsRed/Black+Drivver's Side Fuse Box In A Large White Conn.
Reverse LightGreen+White 16 Pins Conn. Left Of Diagnostic Conn.Pin 2
Left Front Door TriggerDk-Green-Driver's Kick Panel Harness From Back Of Fuse Box
Right Front Door TriggerLt-Green/Red-Driver's Kick Panel Harness From Back Of Fuse Box
Left Rear Door TriggerDk-Green/Yellow-Driver's Kick Panel Harness From Back Of Fuse Box
Right Rear Door TriggerDk-Green/White-Driver's Kick Panel Harness From Back Of Fuse Box
Trunk/Hatch PinBlue/Black-Green Conn. At The Left Side Of Fuse Box.
Hood PinGreen/Black-In Harness Under The Fuse Box Under The Hood
Trunk/Hatch ReleaseYellow/Green+Driver's Kick Panel Harness From Back Of Fuse Box
Notes:
To Bypass the OEM alarm See Diagram.
Trunk Release MotorYellow/Green+Driver's Kick Panel Harness From Back Of Fuse Box
TachometerBlue/Red6 CylTop of Brown Junction Conn. At Left Of Steering
Notes:
Also passenger side behind center console Tach is in a white connector (the closest of the firewall) Pin E19 for the 3.0. For the 2.4L Pin A 15 in a 31 pin connector set in 1 cylinder.
Clutch PedalLt Green-At Switch
Fuel PumpYellow/Green+Driver's Kick Panel Harness From Back Of Fuse Box
Rear DefrosterBlack/Yellow8 Min.Pos.Driver's Kick Panel Harness From Back Of Fuse Box
Notes:
Or at the relay in the fuse box under hood negative trigger set for 8 minutes. See additionnal picture.
Brake WireWhite/Black+Drivver's Side Fuse Box In A Large White Conn.
Parking BrakeGreen/Orange-Top Of Relay In Fuse Box In A Large White Conn.
Horn TriggerDk-Green/Yellow-Left Of Steering Column, In A White Conn.
Sun Roof (Open/Close)Gray/Blue & Gray/Red+At Moon Roof Switch [Diode Isolated Them]
Sun Roof (Limit/Close)Lt-Green/Black & Gray/Red+At Moon Roof Switch [Diode Isolated Them]
Memory Seat 1Blue/Yellow-At Driver's Door Switch In A Green Conn.
Memory Seat 2Red/Yellow-At Driver's Door Switch In A Green Conn.
ITEM WIRE COLOR POLARITY WIRE LOCATION
12 Volts white + front of fuse box, green 6 way connector
Starter white/black + front of fuse box, green 6 way connector
Ignition yellow/black + front of fuse box, green 6 way connector
Power Lock white/red - control push-button in driver door, grey 20 way connector
Power Unlock white/grey - control push-button in driver door, grey 20 way connector
Turn Signal (Left) brown back of fuse box, green 14 way connector
Notes: in alternative, in the wiring harness that supplies the rear services, at the back of the driver side kickplate
Turn Signal (Right) blue/red back of fuse box, green 14 way connector
Left Front Door Trigger green/red back of fuse box (high part), green connector
Notes: in alternative, wiring harness at the back of the driver side wind screen door-pillar cover
Trunk/Hatch Pin pink front of fuse box, green 12 way connector
Hood Pin yellow/red (with original alarm) microswitch fixed to the bonnet mechanical lock
Fuel Pump yellow/black inertial switch
Notes: the inertial switch is fixed in the high part, on the metallic bracket, between brake and accelerator pedals
Alternate view
12 Volts White + Ignition Harness
Second 12 Volts +
Starter Black/White + Ignition Harness
Ignition Black/Yellow + Ignition Harness
Accessory Black/Red + Ignition Harness
Keysense Small Red/White - Green Conn. At The Left Side Of Fuse Box.
Power Lock Pink/Black - Green Conn. At The Left Side Of Fuse Box.
Power Unlock Pink/Blue - Green Conn. At The Left Side Of Fuse Box.
Factory Alarm Arm White - At Driver's Door Switch In A Green Conn.
Factory Alarm Disarm White/Red - At Driver's Door Switch In A Green Conn.
Trunk Alarm Shunt See Diagram
Parking Lights Red/Black + Drivver's Side Fuse Box In A Large White Conn.
Reverse Light Green + White 16 Pins Conn. Left Of Diagnostic Conn.Pin 2
Left Front Door Trigger Dk-Green - Driver's Kick Panel Harness From Back Of Fuse Box
Right Front Door Trigger Lt-Green/Red - Driver's Kick Panel Harness From Back Of Fuse Box
Left Rear Door Trigger Dk-Green/Yellow - Driver's Kick Panel Harness From Back Of Fuse Box
Right Rear Door Trigger Dk-Green/White - Driver's Kick Panel Harness From Back Of Fuse Box
Trunk/Hatch Pin Blue/Black - Green Conn. At The Left Side Of Fuse Box.
Hood Pin Green/Black - In Harness Under The Fuse Box Under The Hood
Trunk/Hatch Release Yellow/Green + Driver's Kick Panel Harness From Back Of Fuse Box
Notes: To Bypass the OEM alarm See Diagram.
Trunk Release Motor Yellow/Green + Driver's Kick Panel Harness From Back Of Fuse Box
Tachometer Blue/Red 6 Cyl Top of Brown Junction Conn. At Left Of Steering
Notes: Also passenger side behind center console Tach is in a white connector (the closest of the firewall) Pin E19 for the 3.0. For the 2.4L Pin A 15 in a 31 pin connector set in 1 cylinder.
Clutch Pedal Lt Green - At Switch
Fuel Pump Yellow/Green + Driver's Kick Panel Harness From Back Of Fuse Box
Rear Defroster Black/Yellow 8 Min.Pos. Driver's Kick Panel Harness From Back Of Fuse Box
Notes: Or at the relay in the fuse box under hood negative trigger set for 8 minutes. See additionnal picture.
Brake Wire White/Black + Drivver's Side Fuse Box In A Large White Conn.
Parking Brake Green/Orange - Top Of Relay In Fuse Box In A Large White Conn.
Horn Trigger Dk-Green/Yellow - Left Of Steering Column, In A White Conn.
Sun Roof (Open/Close) Gray/Blue & Gray/Red + At Moon Roof Switch [Diode Isolated Them]
Sun Roof (Limit/Close) Lt-Green/Black & Gray/Red + At Moon Roof Switch [Diode Isolated Them]
Memory Seat 1 Blue/Yellow - At Driver's Door Switch In A Green Conn.
Memory Seat 2 Red/Yellow - At Driver's Door Switch In A Green Conn.
1 - 7 of 7 Posts
