Here is a little write-up I put together when replacing my upper ball joints at 243k miles (Honda Accord 2007, 4CYL). Perhaps it will be useful to you if you are considering doing the same! Hope it helps!
Thanks, I'm glad you enjoyed my video.FYI - Both the PDF and video were very helpful. For anyone else doing this, you do NOT need to remove the strut entirely, the process in the video is pretty easy to do.
Yea the lower control arm bushings on these Accords tend to seize the bolts in the sleeves. At some point, it might not be worth pressing in new bushings and just getting a new lower control arm.I wish I was aware of the "you don't have to remove the strut assembly" tip when replacing my upper control arm. I ended up breaking this bolt and unable to remove it as it was seized in the bushing sleeve. Had to gingerly drive it to a shop where the bolt was cut, the bushing pressed out and a new one pressed in.
Yes I learned that the hard way. Next time I do any suspension work I'm going to make sure to have a sawzall on hand. At times it's your only out, especially on cars that get a steady diet of winter road salt. By the way I'm a big fan of your videos, they're really top notch. The editing and clarity is second to none.Yea the lower control arm bushings on these Accords tend to seize the bolts in the sleeves.
I replace struts w/ o replacing the spring, big mistake, so had to go back install complete strut replacement. 2 hours to replace both fronts.Thanks for the write-up! This is probably the most detailed guide I've seen yet for the 7th gen accord's suspension. Your guide looks like it would be useful for other repairs as well, such as replacing struts.
