A buddy and I put in the following a short while ago. The whole thing took about 25 hours (with breaks) over a period of 4 days.
JL C5-650 components in front
JL C5-650x coaxials in rear
JL Slash 300/4v2 amp
Infinity 10" Basslink
JL CleanSweep
MTX Re-Q
Dynamat Xtreme on floor, doors, rear deck and under back seat
There are many more pictures here and they all link to a larger version.
We started off by stripping the interior of the car:
Then we jumped right into laying down the Dynamat .. here is the passenger's-side floor:
Door before Dynamat
Door after Dynamat
Fuse holder mounted
Cleansweep wired up, not yet secured
Amp being wired up
One of the rear crossovers mounted
Finished!!
Even though I didn't tune it or calibrate the CleanSweep or Re-Q yet it still sounds amazing. My friend played some lossless music and it blew me away. I never thought I could tell the difference between lossless and 312kbps mp3, but this was a total eye-opener.
Thanks to Jamie I realized that the Accord's head unit puts out full-range signals so I don't need the CL-SSI unit. Jamie also told me it's better to grab inputs for the CleanSweep right out of the head unit, before the stock amp. So over the next few weeks I'll be rewiring all that and removing the CL-SSI.
Also in the plan are Dynamatting the trunk, a bit more under the rear deck (from the trunk-side of it) and the rear quarter panels.
One 'problem' I have is that I mounted the volume knob for the CleanSweep up front next to the shifter. So I'm going to keep the head unit volume level at 30 and calibrate the CS for that. But that means the bass is always going to be at the same gain.
Can anyone think of a suggestion for the best way to get around this? I was thinking of using the BassLink's remote knob to control it. Does this make sense? Leave the head unit at 30 volume and 0 (C) bass gain. Turn the remote knob to its center position and set the gain on the sub to whatever I think is loud enough for normal listening .. then I can use the knob to raise or lower the gain as I like?
I may also re-mount the BassLink so it lies horizontally. Let me know what you think!:wave:
JL CleanSweep
MTX Re-Q
Door before Dynamat
Door after Dynamat
Fuse holder mounted
Amp being wired up
Finished!!
